What is the max size of an email and what is the current size of the storage?
PlusNet
What is the max size of an email and what is the current maximum size of the storage?
Why is there not a notification or graph of amount of storage used / available, as with other providers ?
Can we have one please.
I'd also like to see a size per email column in the account summary.
15 REPLIES 15
itsme
Re: What is the max size of an email and what is the current size of the storage?
Quote from: PlusComUK
You control this by the settings in the email client you are using.
PlusNet !!
itsme
So I assume that you mean you are using Plusnet Webmail for the client. If so both systems can be set by you to display the size of the email.
Edit: and with RoundCube you can see the total usage for each folder.
How ?
I cannot see such an option.
Oldjim
Resting Legend
Fixes: 63
Manage Folders (star bottom left) and you get this
Found it, I have to login to PlusNet Advanced Webmail !!
Which my browser, Camino doesn't like !!
It's OK with Safari though.
bobpullen
Fixes: 315
The maximum size of an email is 100MB minus overheads:
bpullen>telnet relay.plus.net 25
220 avasout04 smtp relay.plus.net
ehlo avasout04
250-avasout04 hello [84.93.217.27], pleased to meet you
250-HELP
250-AUTH LOGIN PLAIN
250-SIZE 104857600 <--- This is the maximum allowed file size
250-PIPELINING
250-8BITMIME
250 OK
We ask that you keep the contents of your mailspace below 1GB.
Because customers' mailboxes do not have a hard quota configured on the server.
Why doesn't it like it? I've just send an email from Roundcube using Camino?
Basic webmail is fine with Camino
Advanced keeps telling me cookies are not enabled, even when they are !!
However, I've just edited Camino exceptions list, and now it's fine with Advanced webmail !!
I'll bookmark bar the Advanced option now, thanks
jelv
Fixes: 10
Quote from: Bob
Worth commenting that that is the limit after encoding. In practice it means a maximum attachment size of around 85MB.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
snozboz
Quote from: Bob
How can I keep track of how much data is in my "mailspace" so that I don't go over 1GB? Given that I have lots of folders on the server and use IMAP, the only way I can think of is to add up the sizes of every folder there.  Isn't there an easier way?
jelv
Fixes: 10
https://addons.mozilla.org/en-us/thunderbird/addon/extra-folder-columns/ is the best I can do and I also have a number of folders and use IMAP - but you still have to add them up.
bobpullen
Fixes: 315
Quote from: snozboz
Quote from: Bob
The new Webmail platform will tell you folder size but only on a per folder basis. We provide plenty of warning before taking any measures against customers whose mailspace exceeds the limits in the AUP.
jelv
Fixes: 10
There's a plugin for squirrelmail! http://squirrelmail.org/plugin_view.php?id=87
AlaricAdair
Champion
If you need to share large files with another person have a look at dropbox.com or sugarsync.com
Now Zen, but a +Net residue.
