VR600 V2 oddity
SteveA
VR600 V2 oddity
Has anyone else seen this on their VR600?
There is no internet connection, usually have to reboot as disconnect doesn't work. Detailed screen says I'm connected but the summary screen says I'm not
This usually happens overnight .
3 REPLIES 3
Fixes: 147
Re: VR600 V2 oddity
Have you looked at the system log found in >Advanced >System Tools?
Running the latest firmware?
Maybe consider posting on TP-Link forum.
Dan.
PeeGee
Re: VR600 V2 oddity
The first "screen" is the connection to the cabinet, the second is whether "the internet" is accessible.
My experience of this is that a change of PN gateway corrects the problem - using "advanced - network - internet" "disconnect" is usually sufficient for me though a reboot is sometimes needed (but I know not why!).
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
SteveA
Re: VR600 V2 oddity
OK so basically the connection is there to the cabinet but somewhere along the line the connection has dropped- I assume due to maintenance being carried out.
The annoying thing is that obviously once it's dropped it doesn't recover....
