Better indoor mobile repeaters on the way
198kHz
Fixes: 42
New Ofcom rules coming in early 2022
https://www.ofcom.org.uk/news-centre/2021/new-rules-to-help-you-get-a-better-mobile-signal-indoors
BT technician (Retired)
3 REPLIES 3
TeeGee
Seasoned Pro
Re: Better indoor mobile repeaters on the way
I am quite happy with the repeater I have at present. The problem now is that the common wifi channels will be swamped with stronger signals from further down the road. Not too bad where I live but high density housing could cause problems.
RealAleMadrid
Fixes: 68
@TeeGee Mobile repeaters do not use Wi-fi frequencies, they re-transmit the actual mobile network signals... nothing to do with wi-fi. I consider them to be virtually useless if you have a very weak or non existent mobile signal you can't make it any better. Wi-fi calling is the way to go, that uses existing wi-fi signals to connect to the mobile network through your broadband connection, no stronger signals required.
TeeGee
Seasoned Pro
@RealAleMadrid
Thanks for correcting me! As you say, another device where there are better alternatives generally available.
