Speed test again
- Speed test again
Speed test again
on
24-10-2017
6:43 PM
- last edited on
24-10-2017
6:56 PM
by
Mav
a few weeks ago i was having lots of speed problems , had a engineer who fitted me a new master socket 5c which sorted it .
But last night i had a few outages see TBB but now i getting slow downs and lots of buffering .
There was suggestions that it was Firefox problem with http://speedtest.btwholesale.com/ so i went to FF57 beta which i thought had fixed it , but am unsure .
Can someone do some tests with FF see what results they get so i can rule out FF other speed tests site show slowdowns but not as bad odd ?
Moderator's note by Mike (Mav): Link fixed.
Re: Speed test again
24-10-2017 6:54 PM
just checkd my router this is what it says when it lost connection
Oct 24 02:03:06 WAN Connection: Fail to connect with some issues.
Oct 24 02:03:06 stop_nat_rules: apply the redirect_rules!
Oct 24 02:03:10 pppd[529]: Connection terminated.
Oct 24 02:03:11 pppd[529]: Modem hangup
Oct 24 02:03:56 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:05:11 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:06:26 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:07:41 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:08:56 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:10:11 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:11:26 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:12:41 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:13:56 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:15:11 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:16:26 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:17:41 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:18:57 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:20:12 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:21:27 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:22:42 pppd[529]: Timeout waiting for PADO packets
Oct 24 02:23:57 pppd[529]: Timeout waiting for PADO packets
25-10-2017 1:58 PM
The BT speedtest appears to give nonsensical results (24Mbits/sec download).
Probably due to its use of the ancient flash plugin.
http://speedof.me/ is believable, as is http://www.speedtest.net/ and these are nearly as good as Plusnet's estimate:-
Estimated line speed:80Mb (This may vary between 70.7Mb and 80Mb) - Checked on 2017-08-29 19:18:04
Current line speed:62 Mb
25-10-2017 2:00 PM
Seems ok to me
Sorry, can't try the btw thing as I don't use flash with FF57
25-10-2017 2:06 PM
@rongtw Why is your ping so high ?
Thats pretty garbage tbh for your connection.
Keys: Help Display mode Restart statistics Order of fields quit Packets Pings Host Loss% Snt Last Avg Best Wrst StDev 1. homerouter 0.0% 6 0.7 0.7 0.7 0.9 0.1 2. lo0.central10.pcn-bng02.plus.net 0.0% 6 9.6 9.4 9.1 9.6 0.2 3. 411.be6.pcn-ir01.plus.net 0.0% 6 9.8 9.8 9.7 10.0 0.1 4. 195.99.125.136 0.0% 6 10.2 10.0 9.5 10.5 0.3 5. 62.172.103.51 0.0% 6 10.1 10.3 10.1 10.9 0.3 6. 195.99.126.73 0.0% 5 10.8 10.8 10.6 11.0 0.1 7. ??? 8. ??? 9. ae0.er02.telhc.bbc.co.uk 0.0% 5 10.7 10.5 10.2 10.7 0.2 10. 132.185.255.148 0.0% 5 11.2 11.2 11.0 11.5 0.2 11. 212.58.244.22 0.0% 5 10.7 10.5 10.3 10.7 0.2
25-10-2017 2:08 PM
My BT Wholesale speed test looks like this:-
A further diagnostics attempt just fails.
BTW This is a Fibre 80/20 line.
25-10-2017 2:23 PM
I see you also have a 10 ish ping, like I said his connection is ****e!
25-10-2017 3:16 PM
@rongtw If you watch this Video, right click on the video and click stats for nerds.... How many dropped frames you getting flash vs html5 ?
I'm asking this 'cus I know your equipment should play this just fine @60fps with no drops.
here is mine for half the video 1080@60fps no dropped frames over wifi of course.
Run it full screen of course!
25-10-2017 3:41 PM
I ran the BT speedtest in a Windows VM running on a Linux host.
It gave approximately reasonable answers - weird isn't it.
25-10-2017 3:52 PM
@30FTTC06 my stats for nerds
25-10-2017 5:41 PM
