Soundbar anyone?
- Soundbar anyone?
- « Previous
- 1
- 2
- Next »
Re: Soundbar anyone?
28-09-2015 11:00 PM
My TV brand is brand new and when I put my ear to the laptop speakers it sounds tinny so a sound bar should be better
29-09-2015 6:55 AM
Unless the TV amplifier is only outputting mid frequencies to avoid overloading the rubbish speakers with a lot of bass that they can't handle anyway.
29-09-2015 7:16 AM
well take it back and complain that the speakers not working properly.
my current tv, it would sound tinny half the time from new (5 yrs ago) after I moved house the speakers gave up within a week, of course moving house invalidates the warranty so I was left with a tv that had no sound, luckily I had a spidif cable and was able ot plug it into the stereo which I have since replaced with a blu ray surround sound unit.
had I complained about the speaker from the beginning I would of had a replacement tv sent out /
29-09-2015 4:36 PM
Quote from: nanotm The optical output option always disables the tv speakers ...
No it doesn't
22-10-2015 4:28 PM
The sound on our Samsung TV is actually pretty decent but we got a Samsung sound bar (I think it's a HW-H75 which we connected via Bluetooth) when we bought it because we expected the TV sound to be pants. While the TV sound is good, the soundbar is amazing - particularly for movies.
Our kit was bought maybe 2 years ago so I'm sure it's even better now.
22-10-2015 5:52 PM
I bought a Goodmans soundbar cost £22 did not make any difference in fact the tiny sound was louder,I put a couple of old laptop speakers and there was a improvement.A friend of mine bought some cheap speakers and he said it cut the tinny sound out altogether so it is worth thinking about before spending too much money
22-10-2015 8:52 PM
Why build your sound system in the shape of a bar?
It's the worst possible shape.
08-11-2015 12:07 PM
I have a Panasonic TV, so opted for a Panasonic soundbar. It has optical input and composite (the two channel wires, red and white , think it's called composite). We use the wires with the tv volume off. You can, with remote buttons for soundbar, switch between optimum settings for voice and music, plus wide-screen.
Bear in mind that these controls vary the settings you choose for the tv sound. So if you increase the bass on TV you get increased bass through soundbar. So the setting up can take a bit of tweaking. We had trouble hearing the audio, but now no trouble at all.
Thoroughly recommend i
http://www.amazon.co.uk/Panasonic-SCHTB8EBK-Compatible-Soundbar-Bluetooth/dp/B00MZNL8RE
- « Previous
- 1
- 2
- Next »
