esmtp used as a smtp relay on a ARM based SBC
richardg8jvm
Hi
Trying to work around a problem with the 2705 router supplied, it drops packets ,
Has anyone configured esmtp to uses as a relay on a ARM sbc, actually a Pogopig E-02, running Arch Linux
I need to be able to use it as a local smtp server , running on port 25 with no encryption, and then forward to a external SMTP server
using SSL,
anyone already done it or similar, not much point reinventing the wheel , if someone has got it working
TIA
Richard
