Size of text box in the messages (help & support)
shutter
Fixes: 65
Can any web designer, explain.... Why, whenever there is a requirement for the customer to send a message to the support team, (not just plusnet) the box provided for the response is less than adequate in size?
I mean, why is the text box on our support pages, only half the width of the available page space...... there is nothing alongside it, the space is there.  You don`t need planning permission to use it, it doesn`t cost any more to use it.....
I have just produced a spreadsheet of figures for  my speed problem, and it does not fit into the space provided. (it may do at the other end) but if I needed to check it, the display is all wrong.
This forum box is adequate, and it is easy to check the message as being sent, instead of looking through a key hole.....
Any chance of making the "important" boxes large enough to be of some use?
26 REPLIES 26
zubel
Re: Size of text box in the messages (help & support)
I suspect the box is optimised for either 800x600 or 1024x768 display, and I'm guessing that your screen is a bit bigger than that.
B.
shutter
Fixes: 65
Don`t be daft......... I have a 15" laptop, and even if I did have a 5foot square screen, the box would appear proportionately larger Roll_eyes
The box is in the left half of the page, the right half of the page is empty.....  Undecided
By your response, half the page would not be viewable on "normal" screens. ! ! !
Edit>>................  I suspect you have never had to use the "my messages" response box ? on the help & support page.....
Oldjim
Resting Legend
Fixes: 63
note that the reply box isn't resizeable either as you alter the window width
shutter
Fixes: 65
so the larger the screen/page, the smaller the box "appears" to be?  Roll_eyes
shutter
Fixes: 65
Seems to me that no-one else cares what size the box is then..... presumably I`m the only one to complain Undecided Lips_are_sealed Cry
Kelly
Fixes: 9
Your referring to this box?
Kelly Dorset
Ex-Broadband Service Manager
Oldjim
Resting Legend
Fixes: 63
no - this one  Grin Grin
shutter
Fixes: 65
Yes, Jim.  You got it right......  Smiley
Funny how the "head of web development"    can`t see  Cool  what I`m referring to,
yet you could..... even in your old age ! ! ! Wink
Kelly
Fixes: 9
Need my glasses Smiley
I think Colin is working on something in that form.  Will ask him.
Kelly Dorset
Colin
I'll change it as part of what I'm working on in that form Smiley
geewizz
That's the same form that comes up when you ask for an upgrade to MAX. That could do with being changed too so that the process is more relevant from the customer's point of view.
I thought I would let you know while you're on the subject anyway.
shutter
Fixes: 65
Thank you for the change (to come)...  Wink
I`m sure it will be appreciated by more than just myself....  Smiley
Could you explain why it was (and is) made that size in the first place?.....  Huh
Is it difficult to re-size it?  Huh
I have the same issue with my bank "log in" page.....
They have a box for inserting a customer number, and the text size is about font size 8.
I have messaged them about it, and they respond saying my browser needs adjusting ! !...
Somehow I don`t think so....  Roll_eyes
if I could adjust the size of font to 14 , it would be too large for the size of box provided !  Cheesy
shutter
Fixes: 65
Quote from: Colin
24 hours later................. still the same size box....    Undecided  .. just used it again.....  Undecided
chillypenguin
I think that you have misinterpreted Colin's comment, he means change it when his current project goes live, not instantly.
Chilly
