Running out of memory
Mav
Fixes: 515
Since building my latest PC that has 8GB RAM I am frequently getting the 'low memory' warning as below.
I know that Firefox can eat memory at times and I frequently use Task Manager to 'End Process Tree' and restart it.
I'm quite sure that I am not running any more programs and open windows than I used to when I had only 6GB RAM yet I never got a warning back then.
For an experiment I have just loaded a lot more apps than usual (screen shot 2) and taken a snapshot of Task Manager Processes and Performance. At this point I will say that I haven't received the warning but I could have half those apps running and I will get it Sad
I think FF can be part of the cause: as I type I can see its memory usage creep up and it's now at around 536000 from what it was at the snapshot below a few minutes ago.
Forum Moderator and Customer
23 REPLIES 23
Strat
Fixes: 565
Re: Running out of memory
Vegas100 is grabbing quite a chunk of memory. Would that be Sony Vegas Pro software?
Mav
Fixes: 515
Quote from: Strat
Yes. Vegas Pro 10 64.
But I have had this memory issue when not even running Vegas Sad
Oldjim
Resting Legend
Fixes: 63
Try looking at processes for all users
Also a search for Vegas Pro low memory throws up a lot of reports and even mentions that closing it leaves some memory hogging processes running
What is your free disk space like and are you running a 64 bit or 32 bit version
Mav
Fixes: 515
Thanks Oldjim but there is only one user on my PC, me Smiley Can't blame anyone else Wink
Strat
Fixes: 565
You might be surprised what it reveals though Smiley
Mav
Fixes: 515
The only extra processes taking any substantial memory are:
audiodg.exe 190.956
svchost.exe  73,898
svchost.exe  56,000
ejs
Aspiring Hero
Fixes: 25
Does it become necessary to end Firefox from task manager? Can't you close it normally? If you go to about:memory in Firefox, there's a "Minimize memory usage" button at the bottom.
Mav
Fixes: 515
It's not necessary to use the task manager but as I often have 2 or 3 windows open each with multiple tabs I used to find that when I want to re-open only the last window closed would have all the tabs restored. Perhaps that has changed now?
Can't find that Minimize memory usage button, though Huh I'm running the latest version.
Waldo
Quote from: Mav
jelv
Fixes: 10
Have you gone in to the right thing in Firefox?
Quote from: ejs
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Mav
Fixes: 515
Found it Smiley
rongtw
Fixes: 12
i would be looking at what programs you have that auto-run in the background , sometimes there are loads that start with windows you dont need but still eat at your memory .
have you tried " RUN " type in MSCONFIG   in  services ,  click Hide all Microsoft , have a look see whats running you dont need ,  then check Startup tab see whats there as well you can stop from running  Wink
or you can try this little program very helpful to see whats in the background http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx  Cool
PS also check free space on Hard drive &  defragment  if needed
GrahamC
This error is usually given when you have exhausted Virtual Memory. Have a check of your Page File setup and make sure it's set to System Managed or at least large enough to suit your 8Gb system.
Mav
Fixes: 515
@rongtw I regularly run msconfig and ensuer there is nothing extra at startup that I don't actually want running.
@GrahamC That's probably it. I set the paging file to zero for the C: (Boot) drive as its an SSD. I have now set a System managed file on one of my other internal drives to see if that helps.
