Running out of memory
- Running out of memory
23-06-2012 3:46 PM
I know that Firefox can eat memory at times and I frequently use Task Manager to 'End Process Tree' and restart it.
I'm quite sure that I am not running any more programs and open windows than I used to when I had only 6GB RAM yet I never got a warning back then.
For an experiment I have just loaded a lot more apps than usual (screen shot 2) and taken a snapshot of Task Manager Processes and Performance. At this point I will say that I haven't received the warning but I could have half those apps running and I will get it
I think FF can be part of the cause: as I type I can see its memory usage creep up and it's now at around 536000 from what it was at the snapshot below a few minutes ago.
Forum Moderator and Customer
Re: Running out of memory
23-06-2012 4:11 PM
23-06-2012 4:17 PM
Quote from: Strat Vegas100 is grabbing quite a chunk of memory. Would that be Sony Vegas Pro software?
Yes. Vegas Pro 10 64.
But I have had this memory issue when not even running Vegas
23-06-2012 4:23 PM
Also a search for Vegas Pro low memory throws up a lot of reports and even mentions that closing it leaves some memory hogging processes running
What is your free disk space like and are you running a 64 bit or 32 bit version
23-06-2012 4:27 PM
23-06-2012 4:29 PM
23-06-2012 4:35 PM
audiodg.exe 190.956
svchost.exe 73,898
svchost.exe 56,000
23-06-2012 4:51 PM
23-06-2012 5:10 PM
Can't find that Minimize memory usage button, though I'm running the latest version.
23-06-2012 7:16 PM
Quote from: Mav Can't find that Minimize memory usage button, though I'm running the latest version.
23-06-2012 7:39 PM
Quote from: ejs If you go to about:memory in Firefox, there's a "Minimize memory usage" button at the bottom.
23-06-2012 9:10 PM
24-06-2012 6:48 AM
have you tried " RUN " type in MSCONFIG in services , click Hide all Microsoft , have a look see whats running you dont need , then check Startup tab see whats there as well you can stop from running
or you can try this little program very helpful to see whats in the background http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx
PS also check free space on Hard drive & defragment if needed
24-06-2012 11:59 AM
24-06-2012 12:25 PM
@GrahamC That's probably it. I set the paging file to zero for the C: (Boot) drive as its an SSD. I have now set a System managed file on one of my other internal drives to see if that helps.
