Running OpenWRT on the Plusnet Hub One (& BT Home Hub 5a)
- Running OpenWRT on the Plusnet Hub One (& BT Home ...
Re: Running OpenWRT on the Plusnet Hub One (& BT Home Hub 5a)
31-03-2016 12:06 AM
I'm stuck with the latter on a RouterBoard RB750 series but if I could get updates and relegate the RB + HG612 to backup use for a point + click upgrade path I may see if I can get me a cheap HH5a from a popular auction website...
F9 ADSL customer since 2004
F9 FTTP customer since 2024
03-04-2016 4:05 PM
03-04-2016 6:24 PM
Just put your [email protected] and password in the relevant boxes.
Edit: where username is your own broadband account name of course.
You may need to click on a "Connect" button if there is one.
12-04-2016 8:23 PM
It is possible to do this without soldering? As in just tape a wire in place?
19-04-2016 9:25 PM
Thanks for the howto, really helped
now the hh5a is booting openwrt can i desolder the wires or are they needed for flashing/updating or can we do that though the gui or telnet???
thanks again
21-04-2016 8:41 PM
Hi everyone,
Since the community site migrated to Lithium I have been unable to reset my password, no idea what email address I used when I signed up and only ever used the site for this one post anyway...
So yeah, glad to see people have been able to do this successfully! I have also added a couple of quick n dirty shell scripts for controlling the LED lighting (tuning off at night, back on in day via cron.etc), i've added them to the link above with the firmware files.etc https://leehobson.xyz/index.php/s/BsHCtMTprdLlfMn
To answer a couple of questions, this does involved soldering 3 surface mount soldered wires unfortunately, although this is relatively easy with a £10 find tip soldering iron, and quick tutorial on Youtube if you have never soldered before. Once OpenWRT has been flashed, you can then de-solder the wires and you are free to p*ss about with the firmware as you please.
And finally flashing this will completely replace the original firmware, however as part of this you can create a backup of the original calibration files and firmware should you ever wish to restore to the original PN/HH5 firmware.
21-04-2016 8:55 PM
Any help with this would be great, I'm scared of locking myself out and unable to reset
25-05-2016 8:32 AM - edited 25-05-2016 8:34 AM
I was reading this thread with interest yesterday.
Is the downloads page link https://leehobson.xyz/index.php/s/BsHCtMTprdLlfMn working for anyone else this morning? (It was fine yesterday)
25-05-2016 4:06 PM
Link seems to be working for me.
I'm just going through the process now and I'm loading the openwrt-lantiq-xrx200-BTHOMEHUBV5A-install-uImage-
[ 355.900000] br-lan: port 1(eth0.1) entered forwarding state
Haven't had any movement now for about 5 minutes. Anyone else encounter this as a problem?
Thanks,
Mike
25-05-2016 4:53 PM - edited 25-05-2016 5:09 PM
Link still not working for me. Web browser returning 'This site can't be reached'.
I was apparently moved onto Plusnet's new Network early this morning and I think this may be a factor. Thanks for checking for me. It looks like it may be a routing problem.
25-05-2016 6:03 PM
It's now down for me too.
25-05-2016 6:28 PM
The domain points to a Plusnet-provisioned broadband line and the line isn't connected at the moment. That would explain why you can't get to it.
25-05-2016 6:47 PM
Ahhh - that makes sense. I'm rather hoping it comes online soon - I'm hoping I can grab a copy of that firmware!
Trying to compile it myself currently.
25-05-2016 9:51 PM
Download site is working for me now.
Hopefully this will send update emails to those above ![]()
25-05-2016 11:19 PM
Sorry people
Yes Bob this is indeed a Plusnet provisioned line, but is a very stable one at that 😛
I've recently been switching my network around a little at home, the https://leehobson.xyz domain is actually pointing to an Owncloud site I host off my Raspberry Pi which is up all the time.
What i've got set up now is a pseudo client bridge with 2x Hub One's. So there is the primary router which is sat where my line comes in, then the second router works as a wireless ethernet-bridge to the primary one and is in another room handling my server, and a few other bits an bobs.
Long story short.. there should be no further issues with the link for anyone wanting the firmware.etc
