Running OpenWRT on the Plusnet Hub One (& BT Home Hub 5a)
core2lee91
Hey up;
So i've recently been experimenting with running alternate firmware (specifically Tomato/DD-WRT/OpenWRT) on various spare routers I had kicking around the place, it then occurred to me I have a spare Plusnet Hub One.
The specs of this hardware are actually pretty respectable;
CPU: 500MHz MIPS
RAM: 128MiB DDR2 @250MHz
Flash: 128MB NAND
Plus it has the 802.11ac, 5x Gigabit LAN ports, xDSL modem, USB2.0 port.etc
I'll not go into too much detail of the benefits of using OpenWRT firmware here, but let's just say it will literally open 100's of extra features and functionality most of which reserved for way more expensive/higher end and even enterprise equipment. More info on what OpenWRT is all about here;
http://www.makeuseof.com/tag/what-is-openwrt-and-why-should-i-use-it-for-my-router/
https://wiki.openwrt.org/about/start
I'm running this firmware as we speak, and so far has been solid as a rock Smiley
Hopefully someone will get some use out of this, I was torn between putting a guide on the OpenWRT Forum or here and as most of us are PN customers with easy access to a cheap Pn Hub One I thought it made sense.
tl;dr let's begin...
First of all you are going to need the following;
  • A soldering iron, basic soldering skills, with the ability to solder 3x wires to an SMD PCB
  • Some type of Serial TTL interface, for this tutorial I will be using a Raspberry Pi but a £3 USB -> TTL interface off eBay will do the same thing
  • Patience! (Mr Sagemcom never expected his budget ISP Router to be violated like this)
  • To be able to take the assumption your warranty and any support from your ISP for this CPE will be void!
There is a guide on the OpenWRT Wiki pages on how this is done, however it did probably take me longer than it needed to do this as there was certain knowledge and steps which where just assumed which is great if you do this kind of thing all the time but not so great if it is the first time you have flashed a firmware using UART.
The OpenWRT Wiki page can be found here;
https://wiki.openwrt.org/toh/bt/homehub_v5a
Step 1:
Get your self a Home Hub One! This (rough) guide is also applicable to the BT Home Hub 5a.
Step 2:
Set up your Serial UART interface, again follow the guide on OpenWRT for this;
Generic info;
http://elinux.org/RPi_Serial_Connection#Connection_to_a_microcontroller_or_other_peripheral
https://wiki.openwrt.org/doc/hardware/port.serial
http://mennucc1.debian.net/lacie_network_space/nokia-ca-42/Serial%20Console%20-%20OpenWrt%20Wiki%20-...
Something to note from this is you do not need to solder a wire to boot_sel3 at the front of the PCB (the yellow wire in my pic), as we don't need it for this.
If like me you have never done this, basically the 'Serial RX' on the Router goes to 'Serial TX' on your Rasperry Pi's GPIO or USB - Serial Interface TTL and the Router's Serial TX goes to Serial RX on the TTL interface/RPi.
On your RPi/Serial - TTl you will also have a 'GND' this MUST be earthed to the Router, I used one of the micro switches on the top;
If you don't run the GND from the interface the the Router, then you will see characters you never even knew existed when you finally connect the console Smiley
So, we should have 3x wires soldered to the Router;
- Serial TX
- Serial RX
- boot_sel2
Then from your interface, you will have 3x wires (RX, TX, GND);
Now we are ready to connect the serial console, as I was using Linux I used Picocom for this;
$ picocom -b 115200 /dev/ttyAMA0
Then short the boot_sel2 wire to ground (same place as the GND running from your TTL interface) and power on the device;
You should see;
ROM VER: 1.1.4
CFG 04
UART
Providing you do see this, then you have the UART console set up and you are well on your way.
From this point onwards you can follow the guide on OpenWRT WiKi. If you are using Linux then download the openwrt-lantiq-bthomehubv5a_ram-u-boot.asc file and send it to the Serial TTY using the cat program;
$ cat openwrt-lantiq-bthomehubv5a_ram-u-boot.asc > /dev/ttyAMA0
This will take a few minutes, you will then be welcomed with the Uboot prompt;
Once here, we then need to load the 'initial' firmware using tftpboot. This part is not very clear at all on the Wiki if you have never done it before but basically you need to run;
tftpboot openwrt-lantiq-xrx200-BTHOMEHUBV5A-install-uImage-initramfs; bootm
This assumes 2 things;
- You are using the IP: 192.168.1.1
- Your 'TFTP Server' is using 192.168.1.2
For the TFTP server I connected an ethernet directly to a Windows computer, set a static IP of 192.168.1.2, and used tftpd64 to connect to 192.168.1.1 pointing the tftpd utility to the directory which contains the file the Router will be looking for;
http://www.trishtech.com/2014/10/upgrade-router-firmware-using-tftp/
I'll not go into too much detail on how I backed up the firmware, but basically I just connected a flash drive to the Router (formatted as FAT32) and did this;
$ mount /dev/sda1 /mnt/
$ nanddump -f /mnt/pnhub_notpornhub.nanddump /dev/mtd6
Then backup the calibration data incase I wish to restore;
$ ubidetach -m 4
$ ubidetach -m 5
$ ubiattach -m 5
$ dd if=/dev/ubi0_3 of=/tmp/pnhub-caldata-backup
$ cp /tmp/pnhub-caldata-backup /mnt
Now we are pretty much done, all we need to do is unlock the bootloader by running this;
$ /hh5a-uboot-install.sh
Now unmount and remove the flash drive, and copy the file openwrt-lantiq-xrx200-BTHOMEHUBV5A-install-uImage-initramfs.tar to the root directory of your flash drive, plug the flash drive back in and mount it again;
$ mount /dev/sdb1 /mnt
Then copy the file to the /tmp directory;
$ cp /mnt/openwrt-lantiq-xrx200-BTHOMEHUBV5A-install-uImage-initramfs.tar /tmp
Then you are ready for the final step, just run;
$ sysupgrade /tmp/openwrt-lantiq-xrx200-BTHOMEHUBV5A-ubifs-sysupgrade.tar
And wait for the magic to happen;
And now you are done, this is a pain in the [Censored] compared to many routers out there however there are many advantages to running this over a stripped down ISP friendly firmware;
Tags (1)
484 REPLIES 484
core2lee91
Re: Running OpenWRT on the Hub One/Home Hub 5a
Also.. you can turn off, change the colour or change the functionality of all the LED's via the GUI. No duct tape needed Cool
http://community.plus.net/forum/index.php/topic,145603.192.html
Anotherone
Champion
Fixes: 21
Re: Running OpenWRT on the Plusnet Hub One (& BT Home Hub 5a)
Hi and welcome to the forum, and thanks for a great, interesting article. I'm sure a few will appreciate it.
core2lee91
Cheers mate. Bit of a niche market I think people who are into this sort of thing, but once it's up and running it's well worth the effort.
Matty123123
Hello, I don't own a Hub, but I'm curious...  Does the WiFi work at the full ac spec or n or just g?, also do you know if the DSL works?.  As its Lantaq chip I'm guessing it does?.
core2lee91
Yeah wireless works at full AC spec, at the moment I'm using the 5GHz radio as a Wireless Client (WDS) connected to another Router then the second access point as a standard 2.4GHz access point. Not tested VDSL/ADSL just yet but I know someone on OpenWRT forums has his running no problems as a modem.
Matty123123
Brilliant...  cheers for the info core2lee91.
HairyMcbiker
All Star
Fixes: 21
Hmm I have a "spare" 5a might give it a try. Was going to sell it, but have kept it for "emergency" use.
core2lee91
If anyone who does this is having issues using it as a VDSL modem and connecting to the internetz, take a look here;
https://forum.openwrt.org/viewtopic.php?id=63246
legume
Nice work 🙂 It's good to know that it works on the plusnet version as well as a "normal" HH5a.
I am tempted to get a HH5a off ebay (if cheap enough as me + dis-assembly + soldering iron may mean h/w death)
just to see some stats. Currently use ECI "modem" + PC as router.
The vlan thing is openreach level.
core2lee91
Yeah, at least at the moment the only differences between the Hub One and the Home Hub 5a are the case and the firmware (is referred to as HH5a in the boot loader.etc).
I'm by no means pro at soldering but a little patience and a £15 jobby from Maplins did the trick.
pwatson
Thanks for the guide - Using the info here in combination with the Wiki, I've got as far as actually installing OpenWRT but I'm now stuck!  The comment about copying the sysupgrade tar file misses out a very vital piece of info - Where do you get it from?  I gather that actually you need to compile the OpenWRT source yourself to get this?
core2lee91
Hi, sorry I didn't realise this file wasn't already on the OpenWRT Wiki page  Embarrassed
Hoping you sorted it, if not I've uploaded everything you need;
https://leehobson.xyz/index.php/s/BsHCtMTprdLlfMn
Smeaghoul
Nice article, when BT gets round to doing a proper job with my new fibre connection and it's working properly I'll be doing something similar, I've now got a redundant adsl router (TD-W8970) which actually has a vdsl modem (disabled), already done serial interface now waiting for USB->TTL dongle to be delivered, if everything works out on the TP-Link router I'll be giving this a go, might take a while to get round to it as my workshop is stacked to the ceiling with stuff I need to repair Smiley
pwatson
Many thanks for making your firmware file available - Now up and running with my HH5A Smiley
