Running OpenWRT on the Plusnet Hub One (& BT Home Hub 5a)
bill888
Champion
Fixes: 40
Re: Running OpenWRT on the Plusnet Hub One (& BT Home Hub 5a)
Download the installation guide PDF.  Refer to 7.5 which will eventually redirect you to 9.1 for PPPoE on FTTC or 9.4 for PPPoA for ADSL connections.  Remember to enter your full Plusnet username.  eg. myname@plusdsl.net
https://openwrt.ebilan.co.uk/viewtopic.php?f=7&t=266
xvoland
Thanks for your reply. I have another problem, HH5 (router) sees the Internet, but not on Wifi. In other words, there is internet through the cable to the router, but through Wi-Fi there is no.
Some ideas?
xvoland
@bill888
Everything I decided, I was confused by the PPOE connection.
Thanks, again!
bill888
Champion
Fixes: 40
hmm, if wifi is enabled (section 9.11 of the guide), your wifi device should be able to see the internet.  Does your device that is connected via wifi have a valid LAN IP address, probably beginning with 192.168.1.x ?   Can you ping the router at default 192.168.1.1?   Try a different wifi device?
If you are using a windows laptop, execute  ipconfig /all command from a CMD command box.
xvoland
Thanks to your hint, @bill888 . I know. I solved my problem, these are some problems in OpenWRT.
Now, I want to update to openwrt-18.06.1-lantiq-xrx200-bt_homehub-v5a-squashfs-sysupgrade.bin but I'm confused by the size of 5mb.
Currently, I use ADSL connection. I just need to update via System->Backup/Flash firmware->Flash new firmware image ?
xvoland
It looks weird...??? 6mb vs 130 mb 🤯🤪
How is this possible?
P.S.: it's before and after upgrade to openwrt-18.06.1-lantiq-xrx200-bt_homehub-v5a-squashfs-sysupgrade.bin
bill888
Champion
Fixes: 40
The ath10k driver for 5 GHz wifi does not report the correct Bitrate.  It is a known 'feature' of the of the open source driver provided for free by Qualcomm.  Don't worry about it.
sysupgrade bin files are typically just over 5 Mbytes in size.  I don't understand why you are querying the size?  (Section 4.3 of the guide includes upgrade advice)
xvoland
Because the installation image have size 11mb...
Anyway, thanks for your hints @bill888
bill888
Champion
Fixes: 40
The installation contains packages to facilitate the installation of LEDE/OpenWRT.  Also the installation image is historically uncompressed, whereas the sysupgrade bin files are squashfs compressed images.  LEDE 17.x is also available in uncompressed image form, but it does not support factory reset function, hence why it was dropped for OpenWRT 18.x.
RRM
Morning All,
Just wondering if someone can help / advise please.
I managed to sometime back flash my old plusnet homehub one to LEDE Reboot 17.0.2 r3435-65eec8bd5f and am now wondering if I need to / can upgrade to a newer version.
I now want to use this router as a Wi-Fi repeater.
Any help really appreciated.
bill888
Champion
Fixes: 40
See section 4.3 of the installation guide for upgrade instructions (I'm beginning to sound like a broken record....)
And section 7.22 if you are pondering upgrading to OpenWRT 18.x.
Repeater extender mode generally doesn't work well if at all with Atheros wifi chipsets.  Here is a recent case:
https://openwrt.ebilan.co.uk/viewtopic.php?f=7&t=1132
See also section 9.10 and 9.14.
FuzzyLogik
Hi Bill
Thanks for all your documentation and advice on the web I have successfully got my OpenWRT HH5A working well with Plusnet with the OpenWRT Wifi fixed firmware.
I mainly installed this for gaming and SMQ - it's way better than the default router.
I have one question that you might be able to answer:
In LuCI, under System>LED Configuration - how do I turn off the big blue bar that is glowing on the HH5A?
(I have turned off the Wifi and DSL or dimmed them) but can't find the item that controls the big blue bar.
My current configuration is using Electrical Tape over it - but I'm sure there is a more elegant solution Smiley
Any help would be appreciated.
All the best
bill888
Champion
Fixes: 40
Regarding your LED query, have you studied section 9.19 of the HH5A install guide?
See settings for 'Power/Status' light.
FuzzyLogik
Yes I have now... sorry I completely missed that.
Must be annoying telling people to read the manual constantly....
Mrg1981
Blatant thread hijack, but for a reason.
I'm having the multitude of 5GHz wifi issues and there's no solution, so I took it upon myself to open the blighter up and make sure it wasn't a manufacturing fault.
I notice that people on here have Lantiq processors in thier hubs, but mine has no manufacturer and the markings are effectively Googlewhacks.
Anyone on here seen the attached chip in thier units?
