Repeated failure of installing Update KB3197954 for W10 Cumulative update for V 1607!
Re: Repeated failure of installing Update KB3197954 for W10 Cumulative update for V 1607!
@OCdragon2 - Save the following as .reg file on your Desktop then double click and accept the changes when prompted and this will disable the Auto Update for you.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU]
"NoAutoUpdate"=dword:00000001
Or simply create the entry manually in the Registry.
OCdragon2
Would this "Reg. Edition" suspend ALL W10 Auto-updates, including their MS's Security-Critical updates as well? If that were the case, this "edition" is NOT targetted for specific Auto-updates and I may have concerns over it though!
Hi, this does what the key implies, and stops all updates regardless of source, so does not appear to be what you're looking for.
OCdragon2
I'm afraid so! Thank you for your suggestion any way!
PeeGee
Have you tried the hide updates system? You can selectively hide (and show) an update with this.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
OCdragon2
I have glanced this link recommended by yourself and would try it later! Thank you.
