Openwrt wifi repeater/bridge: Can connect to btopenzone,browse the network but not load landing page
RichardPoll
Hi guys
ive flashed my old 2704N with openwrt firmware in order to use the repeater function. I've set it up to connect to BT network but I'm not able to reach the landing page to log in to btwifi (www.btwfi.com:8443) even though I am able to browse BT.com etc
My router is getting The following from BT DHCP server
IP             10.84.47.42
mask:        255.255.255.248
gateway    10.84.47.41
DNS.        192.168.22.22/192.168.22.23
ive tried disabling my routers dhcp server which only resulted in limited connectivity and inability to access Lucy. Also tried putting routers LAN IP in range of the BT subnet which also resulted in no connectivity
do you have any ideas what could be wrong?
kind regards, Richard
