Remote Connection to Synology NAS Drive
Tykebike
Hello everyone,
I'm trying to set up my Synology DS224+ and have got as far as the option for email delivery but I'm stalled when it asks for the SMTP Server and Port. I have entered the incoming server address and the incoming port 993 but this has been rejected.
Could anyone suggest how to fill in the boxes in the attachment below?
2 REPLIES 2
outcast
Aspiring Champion
Fixes: 19
Re: Remote Connection to Synology NAS Drive
SMTP is the outgoing port - so unsurprising it failed if you entered 993 (incoming port number for IMAP)
SMTP these days is typically port 587, although 465 and 25 should also work.
You'll need to look-up your email provider's SMTP server URL or IP address.
Tykebike
Thanks!
