Problems with Virtual Machine Mint 16 (title changed) !
- Re: Problems with Virtual Machine Mint 16 (title...
Re: Problems with Virtual Machine Mint 16 (title changed) !
28-03-2014 4:21 PM
Look at my screenshot. When the VM is running, click on devices (with the stick plugged in) and it should appear in devices/usb
1st is me attaching the usb stick
2nd is the explorer window showing the contents.
There is also a really good help built in.
28-03-2014 4:24 PM
1) Start XP
2) when xp is running click on Devices at the top, bottom of the list should be install Guest Additions......... click on this which should start an installer in XP
3) Follow the installer instructions and reboot
4) Follow what I said previously about right-clicking the usb icon, highlight the usb device you want connected and left-click on it
Hope this works
{edit} spelling mistake oops
28-03-2014 4:29 PM
28-03-2014 4:33 PM
Camera pics are ok for me at the moment !..
28-03-2014 5:49 PM
Open a terminal and enter
sudo service vboxdrv restart and see if that helps.
Or just reboot the pc.
28-03-2014 6:16 PM
![Cheesy Cheesy](/html/@69488338D0B3891CC5F8AEAEEB30C648/images/emoticons/cheesy.gif)
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
28-03-2014 6:59 PM
gerry@gerry-Inspiron-1545 ~ $ sudo service vboxdrv
[sudo] password for gerry:
Usage: /etc/init.d/vboxdrv {start|stop|stop_vms|restart|force-reload|status|setup}
re started vm and still no usb connected...
shut down pc.... re started.... restarted vm and still no usb connected... !
28-03-2014 7:27 PM
Quote sudo service vboxdrv restart
28-03-2014 7:31 PM
![Embarrassed Embarrassed](/html/@6CEFBAD878A40FF337662307A879A7FD/images/emoticons/embarrassed.gif)
will do it again....
OK... been there... done it again..... got this...
erry@gerry-Inspiron-1545 ~ $ sudo service vboxdrv restart
Stopping VirtualBox kernel modules ...done.
Starting VirtualBox kernel modules ...done.
and still no usb attached on Devices or on right click on the icon at the bottom of screen...
28-03-2014 8:40 PM
Quote Checked Users and Groups... added vboxusers .... and it appears in the groups tab....
Not sure if this means the group exists or you have added your username
Try the following in Linux Mint terminal
sudo adduser yourusername vboxusers
Replace yourusername with your own, then log out or reboot
Once back in linux mint desktop, restart virtualbox and your xp
28-03-2014 10:26 PM
@ gtowen..... You`ve cracked it ! ..
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
usb now appears on the Device listing.... and also on the right click down below....
The quote above was only a " guess work" thing I did... and I was talking about adding vboxusers and seeing it on the "groups" tab...
Don`t recall any instructions about actually adding my username...( have looked back and can`t see any... might have missed it tho ! )..
Anyway.. next problem is to get the Serial port functioning...
What happens here is I have a USB/Serial adapter, and it is showing on the Devices > USB listing ... however on the Serial Port, it shows "disconnected", and if I try any of the alternatives it shows "invalid settings detected"... and the OK is greyed out when that shows, so I can`t "create pipe" or allow the machine to do it automatically.
Any ideas ?
28-03-2014 10:32 PM
28-03-2014 11:02 PM
( I think there might be some electronics in the D9 shroud, but not sure)..
it uses a PL2303 driver. and I am using it on WIndows and also got it working on MINT ... so it shouldn`t be too difficult to get working...
( well, that`s what I thought about the USB/memory stick ! ! ! ! !).
28-03-2014 11:15 PM
https://www.google.co.uk/?gfe_rd=cr&ei=zAE2U56KLYnR8geRh4B4#q=virtualbox+USB%2FSerial+adapter&safe=o...
28-03-2014 11:32 PM
Thanks to you and to HB for all the help and patience you have with me...
Much appreciated.
