Lock pdf file?
- Lock pdf file?
Lock pdf file?
30-03-2014 10:33 PM
I keep copies for my records but want to be able to prevent each file from being altered. I haven't found an option in pdf Reader or pdf XChange Viewer and can't afford Adobe Acrobat.
Does anyone have a possible solution to this, please?
Forum Moderator and Customer
Re: Lock pdf file?
30-03-2014 11:37 PM
One or two in Google!
Or, set the pdf to Read Only in its Properties.
York.
Re: Lock pdf file?
31-03-2014 10:21 AM
https://ra5-downloads.phpnuke.org/en/c156342/pdf-locker-free-download-full-review
Re: Lock pdf file?
31-03-2014 12:53 PM
Re: Lock pdf file?
31-03-2014 2:45 PM
@NedLudd Thanks for the suggestion but I do prefer to keep as a pdf file. Couldn't see any options within Acrobat Reader or XChange Viewer to set to Read Only.
@gtowen I saw that when I did a search - just wondered if anyone had any other ideas
@ejs I didn't realise there was another version available. Have downloaded it to try. Didn't really want to password protect as it would still be editable. No-one else will have access to the files but accidents can happen and I have made changes I didn't necessarily want to in error then save them before so just wanted to avoid that happening again. All in all it's not worth too much effort in solving and I can easily save the password in the filename if I go that route.
Thanks again for all the suggestions.
Re: Lock pdf file?
31-03-2014 6:11 PM
York.
Re: Lock pdf file?
31-03-2014 6:43 PM
Obvious now it's been pointed out. Thanks - that should be enough for my purposes.
Re: Lock pdf file?
31-03-2014 7:04 PM
York.
Re: Lock pdf file?
31-03-2014 7:51 PM
Re: Lock pdf file?
01-04-2014 7:52 AM
I certainly had thought you were referring to stopping someone altering it intentionally not unintentionally as now seems to be the case.
Another way - somewhat perverse I must admit but it'll work - is to change it to a jpg, then printing the jpg as a pdf file. You then get a pdf file that cannot readily be altered since it contains a graphic image not text. Quality will suffer though.
Re: Lock pdf file?
01-04-2014 1:23 PM
Your last suggestion wouldn't be worth the effort but worth bearing in mind.
