Printer offline
FIXED- Subscribe to RSS Feed
- Re: Printer offline
15-07-2021 11:54 AM
Hi Everyone
I have last week bought a BT Hub 6 and connected it up following Balderick1's excellent step by step guide.( thank goodness)
So far so good - the BT Hub 6 has much better wifi than the awful supplied hub from plusnet which has caused us a lot of grief over the last year in many ways - dropping out .
However I cannot connect my Cannon MG3150 printer wirelessly now. I have a mini mac which shows the printer to be "off line". I have tried a few things from the internet but no connection .
Cannon's instructions say "press the WPS button, please refer to the access point manual".......???
Is this the WPS wifi set up button on the side of the BT hub ?
Am I safe to do this as I do not want to loose connection with everything ? Is there a simple way via going into the router control panel ?
Fixed! Go to the fix.
Re: Printer offline
15-07-2021 12:09 PM
Moderators Note
This topic has been moved from Chat to Tech Help
Re: Printer offline
15-07-2021 12:14 PM
Yeah it's the button on the side of the hub, pressing it won't break anything.
15-07-2021 1:35 PM
When you press the hub WPS button a blue light will flash for two minutes. During this time do whatever your Cannon instructions tell you to do. After it connects the light will show solid blue then go out. If you miss the two minute window the light will go out, just start again. No other connected devices will be affected by doing this.
Re: Printer offline
15-07-2021 2:29 PM
Thanks Dvorak and a big thanks to Balderick1 . connected and working. Brilliant .
