Standard text messages via an iPad
Annplumb
Yesterday my iPad and my husbands very old iPad both lost connection to the internet even though our desk top computer was still connected. This lasted for quite some time. Now today, neither iPad can send or receive standard text messages. They will only send or receive iMessages. I can still send and receive standard messages via my iphone but not the tablet.
spoke to Apple they say it’s the phone provider. Phoned the phone provider they say they only deal with phones not tablets so have no idea. I’m completely useless with technology so don’t know where to turn next.
Could it have been caused due to the issue I had earlier with no connection to the internet. Has anyone out there ever experienced something like this and would know how to rectify as I prefer using my tablet as print is larger and easier to read.
7 REPLIES 7
Legend
Fixes: 245
Re: Standard text messages via an iPad
@Annplumb I can't give any assurance that this will work but it is worth a try. Totally switch off both iPads, wait a couple of minutes, then restart them. Apple devices sometimes throw the occasional unexplained 'wobbly' which this approach sometimes fixes.
BTW - I have asked for this to be moved to a more appropriate board.
Annplumb
Thank you. Unfortunately I did turn off both devises and then re start them and it hasn’t resolved the issue. I’m just not knowledgeable enough to know/understand whether these issues relate to WiFi or the phone network. There has definitely been a problem with our iPads losing the WiFi connection since we moved to super fast broadband. Before that we never had a problem. could it be that the signal isn’t strong enough and needs some sort of booster. Sorry if these questions appear stupid but as mentioned I don’t understand this new technology 😂
Fixes: 1,482
Moderators Note
This topic has been moved from ADSL Broadband to Tech Help
Fixes: 1,482
You could try splitting the 2.4 and 5GHz wifi bands, it helps with Apple products.
Navigate in a web browser to 192.168.1.254.
Click Advanced Settings
Enter your Hub admin password when prompted (unless you've changed it, you'll find the default password on the settings card)
Continue to Advanced Settings.
Click on Wireless.
Click 5GHz tab.
Change 'Sync with 2.4Ghz' to No.
Change the name of the 'Wireless SSID' - I added a '_5' on the end.
Save the changes.
You can then select which one you want per device.
In terms of text messaging I'm assuming that they are cellular iPads, if so have you tried turning off the WiFi on the ipad an trying to send a text?
Mustrum
Fixes: 76
I did not think it was possible to send an SMS txt on a WiFi iPad, however it seems How to Geek knows, and it relies on a connection to an iPhone.
Fixes: 1,482
Which will rely on the WiFi connection.
See what happens with the split.
Annplumb
It’s not a cellular iPad. It’s just a normal iPad. My iPhone is set to “text message forwarding” so My iPad should be receiving any standard text messages that the iphone receives. Also, my iPad was able to send iMessages and standard text messages. It’s only been today that standard text message receipt/send has stop working. the iMessage facility is still working fine. It’s doing my head in. Everyone is saying it’s not their issue.
