Plus Net login details not recognised by Mac OS 10.11.3 (El Capitan)
- Re: Plus Net login details not recognised by Mac O...
20-01-2016 12:09 PM
Re: Plus Net login details not recognised by Mac OS 10.11.3 (El Capitan)
20-01-2016 12:12 PM
If it's the connection, then the router should be the place that the details are saved.
If it's email, you need to ensure that SSL is turned off in the email settings.
20-01-2016 1:03 PM
20-01-2016 1:09 PM
Now I cannot get my MacBook to connect over wifi, it works fine via Ethernet cable though.
I keep getting asked to enter my password at the wifi login screen, and despite doing this several times it still does not work. I'm pulling my hair out here and the wife will divorce me soon as every evening I'm trying to fix this problem.
All my other Apple, Android and Microsoft devices work ok.
In need of some help here!!
20-01-2016 4:50 PM
http://community.plus.net/forum/index.php/topic,137695.0.html
Quote The fix was as follows:
1) Turn off the wifi, either via the router gateway or just turn off the router.
2) Turn on your Mac
3) Click the wifi symbol and select Open Network Preferences
4) Make sure AirPort is selected and pres the Advanced... button
5) select the TCP/IP tab
6) Under configure IPv6, select Off.
7) press OK then Apply and close down the Network window, then reboot.
8 ) While rebooting you should be able to turn the wifi back on.
9) Hopefully you should now be able to enjoy your wifi
06-02-2016 12:46 PM
I turn wireless off, then on again. Sometimes that does it. Sometimes it asks for the password, but when I enter it, it rejects it. I close wireless, open again...and so far, after 2,3 or 4 cycles of this, the Macbook connects.
I have a plug-in signal booster upstairs: is that confusing it somehow? But that's obviously on the same network, using the same router, so why should that matter? It seems to be something to do with IP recognition - but why does it work, and then not work next time? Even though I tell it to remember the network, it doesn't.
Any ideas? I'm getting bored of having to do this every time my Macbook goes to sleep...
Many thanks.
06-02-2016 8:38 PM
06-02-2016 8:59 PM
Quote from: cjd888 Since getting a new Plusnet Fibre router a week or so ago, my phone, ipad and my older iMac, running 10.5.8 - even my formerly reluctant LG smart TV - are all fine.
if it's a hub one, split the 2.4 and 5GHz networks by changing the SSID in advance wireless settings.
31-03-2016 9:34 PM
Quote from: dvorak if it's a hub one, split the 2.4 and 5GHz networks by changing the SSID in advance wireless settings.
This worked for me on a Macbook Pro.
29-07-2016 9:53 PM
I am having similar issues, basically my iMac running OS 10.11 will not auto connect to the router. I have already spilt the bands, but for some reason every time i reboot the mac I have to reenter the network and password?
I have just changed to a Plusnet One Hub, no issues with the old router, so I'm thinking there may be a firmware update or something to run?
Its very enjoying, any help appreciated.
on 02-10-2016 9:50 PM - last edited on 02-10-2016 10:16 PM by Mav
Hi mate, did you ever find a solution?? This is exactly whats happening to me & ive tried everything but cant get to the bottom of it
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
02-10-2016 10:19 PM
Duplicate post removed
Forum Moderator and Customer
11-10-2016 5:14 PM
I'm having same problem with Mac 10.6.8, and have tried the list of things to do (1,2,3,4,-9), which has not sorted the problem. I get online eventually but i have better ways to spend my time. Plusnet, any ideas?
11-10-2016 5:16 PM
i have exactly same problem, with MacBook Pro 10.6.8.
