Pi-Hole Query
Fixes: 480
Pi-Hole Query
Being bored and looking for a little project I have bought a Raspberry Pi Zero 2W and installed Pi-hole on it. This is working fine and has also enabled me to eliminate the irritating adverts from organisations that I will never use that clog the top of web searches.
Looking at the Pi-hole stats I have found a couple of mysterious new wireless connections, neither appear in the list of devices in the Hub 2 Advanced/My Network list of devices. I have the Pi-hole DHCP server switched off.
One of these mysterious connections seems to be a list of every DNS lookup. Is this a 'feature' of the Pi-hole or is there a back door link of which I am unaware reporting my every move?
As an aside, I note the documentation states that I need a 2.5A PSU for the Pi Zero, measured current when running this software is 0.12A - hence I have found a use for the Hub 2 USB connector:
36 REPLIES 36
bobpullen
Fixes: 331
Re: Pi-Hole Query
Where exactly are you seeing these 'connections' and how do you know they are wireless?
I'm familiar with Pi-hole but am struggling to visualise what it is you're referring to.
Fixes: 480
Re: Pi-Hole Query
@bobpullen
Ah. perhaps they are not wireless, my assumption, as I know that they are not wired.
When I go to the Pi-hole Dashboard they appear as local IP addresses under 'Top Clients (Total)' with an IP address that does not appear in the list of Hub 2 devices, either active or disconnected. Opening the address gives me, for example:
bobpullen
Fixes: 331
Re: Pi-Hole Query
Few of those lookups are to a DNS over HTTPS server.
Can you see the IP under Tools > Network, and if so, does the corresponding hardware address offer any clues?
Fixes: 480
Re: Pi-Hole Query
Thanks Bob,
Tools/Network showed me the answer.  It was a bit of finger trouble plus being fooled by my IPhone having different MAC addresses for the wireless bands.
Fixes: 118
Re: Pi-Hole Query
@Baldrick1
I hate it when people put ideas in my head.
Do you connect the Pi to the router via ethernet cable?
Is the power source from the Hub2 to the Pi a standard USB cable?
I guess I'd need to buy
Rasperry Pi Zero 2w
Pi Case
SD card
Fixes: 1,495
Re: Pi-Hole Query
You don't need to buy a Pi, you can run it under Docker on windows or other OS as an experiment Smiley
Or even install it directly on Windows https://github.com/DesktopECHO/Pi-Hole-for-WSL1/
Fixes: 480
Re: Pi-Hole Query
If you go the Raspberry Pi route:
The W in Pi Zero 2W means it is wireless, so no Ethernet cable required
You need a USB A to micro USB cable for the power.
You need a case.
To program the Pi you need:
A means of downloading an operating system on to a micro SD card, I have a USB adapter. I used the simple RaspOS version of Debian.
You then need to download and install the Pi-hole software, to first turn the Pi into a working computer you need:
A mini HDMI to HDMI cable to connect to a monitor.
A micro USB to means of connecting to keyboard and mouse. I used a micro USB to USB A cable plus a female to female connector into which I could plug my PC Bluetooth usb gizmo.
There may well be easier ways to do it but I wanted to try something different, this was a little project into unknown territory to keep my brain ticking over.
Re: Pi-Hole Query
It is worth noting the current Raspberry PI imager allows for the enabling of ssh and the setting of the wireless name/password. So the HDMI and USB cables are not really needed, just one for the power, use a terminal app such as PuTTy for ssh.
You can find the pi IP Address via your DHCP allocated IP Address list of you router, in the case of the Hub Two >Home >My Device
HTH
Fixes: 118
Re: Pi-Hole Query
@dvorak
Thanks for the suggestion. However, I still run Win7 so it appears to rule that out. Also, I occasionally shut down the machine to boot a NUC box with Linux Mint.
@Baldrick1
I already have a multi card reader so programming the SD card wouldn't be a problem.
I think I would need a USB power cable on top of what I previously listed (unless I find one lying around) so around £35 seems to cover everything. Looks like I'll be spending some money soon.
Fixes: 118
Re: Pi-Hole Query
@Baldrick1
The game has begun. £32.97 has got a Raspberry Pi, Case, USB micro lead and an SD card on order.
I know I need to set an Static IP address in Pi-Hole, some where outwith the Hub2's normal range. So it'll be 192.168.1.? but I'm not certain of what the normal range is. Any ideas?
Fixes: 480
Re: Pi-Hole Query
@bmc
It’s 2-63 I think. I just left it on DHCP and reserved the allocated IP address by selecting ‘always use this IP address’ in the advanced hub 2 network settings.
I have been struggling with getting a domain that I added to always block. I’m hoping that I have found the problem as being the DNS being cached in the browser prior to adding the pi hole.
Fixes: 118
Re: Pi-Hole Query
@Baldrick1
Thanks - I'll report back next week on how things go.
Fixes: 118
Re: Pi-Hole Query
Well, stage one completed (I think).
The SD card showed up today and following the instructions in the link below I've now got Raspebrry Pi OS installed with SSH and my network details.
https://www.wundertech.net/how-to-setup-a-raspberry-pi-zero-without-a-monitor-keyboard-or-mouse/
I'll only find out if it worked when the Pi shows up and I try to connect wirelessly.
Fixes: 118
Re: Pi-Hole Query
Stage two completed (eventually)!!!
I manually added the required "ssh" and wireless settings to the SD card but for some odd reason between the card reader and the Pi itself they got lost so no connection (two attempts).
So I re-installed the O/S (again) and used the imager settings to add in all the details I required. I now have a Raspberry Pi recognised by the router.
Just the Pi-Hole install using Putty to do.
