Sky Glass - No Internet
bangorpootsy
When trying to connect my TV to the Hub two, DHCP assigns an IP Address but no Internet is found.
I’ve tried connecting using WPS and manual connection but without success. It’s like no DNS address is given to the TV.
Does anyone else have the same setup and hopefully a solution?
3 REPLIES 3
Mav
Fixes: 518
Re: Sky Glass - No Internet
I'm no expert in these matters but, until someone more knowledgeable pops along have you tried changing the DNS servers to Google's;
8.8.8.8 and 8.8.4.4
Forum Moderator and Customer
bangorpootsy
Oddly you can’t change the DNS on the Sky Glass. It’s only an Automatic connection using a search or WPS. No opportunity to fine tune.
Have you checked the Sky help pages?
https://www.sky.com/help/articles/sky-glass-no-internet-connection-osm
It suggest performing a reset, have you done so?
