ONT extension DC power cable and Fibre cable used
Fixes: 144
Rather than adding a new Power socket for the ONT I am looking to extend the DC power cable, just need to confirm the specification, this cable would be no longer than 3 meters
From my research here and elsewhere suggests the PSU is 12v 0.5a 6w with DC jack size being 2.5mm x 5.5mm.
Just need to confirm the jack size of 2.5 x 5.5 mm and would this be usable for the various models of ONT used by Openreach?
The alternative to using a DC power extender would be to run the Fibre cable to a position where there is a power socket
Never being involved with Full Fibre installations be interesting to know what the Fibre cable used by Openreach within the house, how robust is it?
I think they use EZ bend products so the minimum bend would be that of a £2 coin. It will be run in trunking to protect it.
Thanks in advance
18 REPLIES 18
Fixes: 568
Re: ONT extension DC power cable and Fibre cable used
@Dan_the_Van I believe Openreach will provide up to 10m of internal fibre. Normally they would clip to skirting boards but if you provide trunking then I'm sure they will use that. Your min bend radius might be a bit tight!. Are you aware of the diy fibre extension kits here https://www.premitel.uk/consultancy/expert-advice/how-to-relocate-the-ont-fibre-termination-point/ ? Looking at the box used to coil excess fibre it looks something like a 5cm bend diameter.
Not sure on the power connector specs and whether they are different depending on the ONT. Unfortunately I'm not at home so cant measure mine either...
Fixes: 109
@Dan_the_Van
This is my incoming fibre cable installed late 2017.
I would consider moving the ONT if your'e happy with the cable being stapled to the wall. Speak to the installer on the day.
outcast
Aspiring Champion
Fixes: 19
@Dan_the_Van
Everything I'm finding suggests that typical Openreach ONTs use 2.1mm x 5.5mm connectors,
I've yet to see a 2.5mm x 5.5mm search result.
The most definitive answer I've found is in the Openreach SIN_506 document (attached below) on pages #28 to #30
showing that ALL Openreach ONTs are 2.1mm x 5.5mm
Another alternative would be running PoE (Power over Ethernet) to the ONT, then using a power splitter to locally provide the 12V to the ONT, that way only having one cable running to the ONT instead of separate ethernet and DC extension cord.
Example of a power splitter - Amazon : TP-Link TL-PoE10r
Fixes: 109
@Dan_the_Van
The other option could be the installer is happy to run the cable externally so it comes in where you desire. No internal cabling required.
If this is not possible, do not install the internal trunking until positions have been agreed with the installer. You should be able to quickly put it in place once the wall is drilled through. Could be done while the external CSP is being installed.
Fixes: 144
Thanks all for your replies.
Currently the copper line is Underground and terminates to a B66B Junction Box at the front of my property, from there it goes internally to a small cupboard where the Master Socket 5c and MK4 faceplate is located. It is not clear to me if the cable internal run is via conduit to the Master Socket which is fitted to a stud wall
This cupboard is where my current Hub, WAP, NAS and VPN servers are located with a powerline connection (don't ask) to the garage and a garden WAP
So I am guessing using the outside wall to take the fibre cable to the same cupboard which has an outside wall,
So my concern on where best to locate the ONT in the cupboard as that's where I want it, I've concluded to have the Fibre cable run to the ONT position as this will be the simplest option. The fibre cable would be no more than 3 metres.
Thanks again for the suggestions.
Fixes: 109
@Dan_the_Van
My only concern would be if running it externally is if it needs to go round a corner of the house. Potential for damage at the corner. You speak to the engineer to agree a course of action. He might say no, not possible and that it needs to come is at the front wall. Have a back up plan just in case.
As to what happens in the cupboard  - you are free to do what you like.
Fixes: 144
@bmc
It can't can't go through the wall its the downstairs cloakroom no power, just a toilet and sink
Fixes: 109
@Dan_the_Van
Perhaps I should have said somewhere on the front wall.
However, this appears to strengthen the case for bringing the cable round the outside wall.
Fixes: 472
@Dan_the_Van
I am powering my ONT via an APC UPS. To connect it I had to use the supplied 2.5/2.1mm pin adapters to interface the APC 2.5 mm pin connectors to be compatible with the 2.1mm pin/socket size used by the ONT and its PSU.
Fixes: 144
Thanks to everyone who has posted
@outcast
The TP-Link PoE would be a bit over the top for 3 metres, I did look for a reference paper by openreach on the specifications for a ONT but I failed, your attachment was what I was looking for.
Now have it confirmed the size by the attachment and @Baldrick1 I can proceed with planning what I like to have done.
Fixes: 109
@Dan_the_Van
I see from another post today that FF is now on order.
I would repeat my sugggestion that no work is done until you've spoken to the engineer on the day and agree the access point. If trunking is required you should be able to fit it quickly while the outside work is done.
Do let us know how it goes on the day.
Fixes: 144
@bmc
I've now come to the conclusion to have the ONT installed to an outside wall in the cupboard.
I will use a 12v dc extension lead and a 4 metre length of cat 6 utp between the router and ONT, the cables purchased are flexible so no worry of damaging the fibre core.
The redundant Openreach Master Socket will be converted to a power socket.
So my only worry now is the 90 degree turn on the outside wall, I've got until 15th April to work out what might be needed, if anything.
Not sure why I'm overthinking this, I've planned and installed far more important projects than this.
Thanks again for taking an interest.
shutter
Fixes: 67
@Dan_the_Van
Right angle corner problem.........
see the pic !
 You could leave the loop "free floating" ..or you could fix a wooden block ( say 2" x 2"   ) to the corner and secure the cable down on the top ( or below ) .
The above pic is a "mock up" not "reality"  ! ... Cheesy
RobPN
Fixes: 14
IMO, a somewhat ridiculous suggestion for an outside cable which I'm sure an OR installer would go for - NOT!
I'm surprised nobody has suggested the following, quickly mocked up using a bit of old 4" x 4" timber etc. in my back yard.
Could also be used where two walls meet forming internal angles.
(Or if the outside wall is brickwork, the mortar bed could be chased out to accommodate the cable thickness and curve required.)
