New monitor - advice please
- Re: New monitor - advice please
18-05-2015 10:45 AM
Would I really notice the reduction in image quality with the 27" as compared to the 24" due to its lower pixel density from about 36" away (note I don't watch films on it)
18-05-2015 10:50 AM
The answer depends a bit on how good your eyes are.
18-05-2015 11:01 AM
A comparison of 24" and 27" both at 1920 x 1080 would give a good indication
18-05-2015 2:15 PM
18-05-2015 2:23 PM
Personally I found 22" was the limit of what I could reasonably use on my desk at home, my work desk where I did cad retouching of images and viso cct designs I had a 36" widescreen and a 17" square job for the different applications to run on.
Take a tape measure with you to the store and check the normal use distance as well, my desk is 30" wide but the distance between me and the screen under normal conditions is about 20"
18-05-2015 2:24 PM
I am not sure I agree with that as the 27" 16:9 is 0.52" deeper than a 24" `16:10 and for documents it is the physical size available rather than the pixels
@nanotm
As I said in the original post my normal distance is 36", Also size, within reason, wouldn't be a problem but it will now depend on what they look like as recommended by w23
18-05-2015 4:06 PM
I wouldn't bother with a 27" unless you have a lot of windows to look at,
If you can find a 27" (2560 x 1440), that would be worthwhile.
But they are ridiculously expensive.
18-05-2015 4:13 PM
I will be interested in the answer as my monitor is against a window
18-05-2015 4:27 PM
Quote from: Oldjim @wisty
Windows taskbar is 40 pixels, when you resize an office window the status bar & ribbon don't change height and eat another 120 or so vertical pixels. So on your 1080 you have only about 920 pixels for text. On the 1200 its 10490 or about 14% more (i.e in page with mode for a given document width you will have several extra lines visible) .
I have two tablets one is 2160x1440 the other is 1920x1080. In landscape mode the latter feels like I am trying to edit through the letterbox (it also feels too narrow i portrait mode!!)
18-05-2015 4:45 PM
It would be different for a spreadsheet
I suspect that the difference is the actual screen size as tablets are so much smaller
18-05-2015 5:04 PM
Quote from: Oldjim It must be my old age but what have the windows got to do with it
What are all those little rectangular boxes?
18-05-2015 5:07 PM
24-05-2015 1:26 AM
Excellent quality and has a swivel mode for reading/editing documents in portrait mode.
Forum Moderator and Customer
29-06-2015 2:42 PM
I had a look at these forums as they were on line and comparing to my present monitor (22" 1650 x 1080) there is no significant degradation so I am good to go with either an IPS or a PLS 27" monitor
07-07-2015 12:59 PM
As usual Amazon's returns policy is absolutely superb
