WiFi
WiFi
08-07-2015 3:18 PM
Hi all.
Is there someone who can explain as to which password I use to enter into my Moby phone to connect to wlan with plusnet wifi
Is it the router p/word or WiFi p/word. They are printed on separate cards which came with router/modem.
Your help eagerly awaited.
Cheers
Cheers
1 REPLY 1
Re: WiFi
08-07-2015 3:37 PM
The WiFi password on the back of the router or the card supplied.
Customer and Forum Moderator. Windows 10 Firefox 100.0.1 (64-bit (64-bit)
