Master Socket shift
Mustrum
Fixes: 81
Re: Master Socket shift
What about the other end? It's only two wires that you need, and you can test easily with a phone - once you get dial tone the rest should be OK.
ejs
Aspiring Hero
Fixes: 25
I think you're using the colours in the new cable incorrectly. You should be using the blue wire with the white/blue wire, they will be colour coded pairs. If you use the orange wire and the blue wire, that's a "split pair", using one wire from each pair, defeating the purpose of using twisted pair cabling.
NorthEasterner
Thanks @ejs I will give that a try.
I didn't know it mattered to which cable was used as long as they are linked up correctly with A/B
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up Thumbs_Up
Mustrum
Fixes: 81
You would not a get a BT/Openreach engineer not using matching pairs, so if they ever get called out they would know someone else did a re-wire.
NorthEasterner
Can successfully say speeds returned to normal having white into blue and orange into white/blue.
Will post an update later if keeps its connection or not.
Thanks 😁😁
NorthEasterner
Back to square one Embarrassed
Scratching my head as to why not working - intermittent/low speed. No dial tone.
I have wired Blue (from line) into Blue (new wiring) which ends up in socket B. And Orange (from line) into White/Blue (new wiring) which goes into socket A.
Ticked_off
Screen Shot 2018-03-27 at 22.01.00.pngScreen Shot 2018-03-27 at 22.01.09.png
twocvbloke
Try a different pair, you could have a break in the wire somewhere (not uncommon, and very annoying to fix without things like tone oscillators and cable test equipment)... Smiley
EDIT TO ADD:
Looking at the pictures again, it could be you have the A & B wires reversed, Blue/White should go to Orange wire and White/Blue to the White wire, A being 0v to Earth and B being -50V to Earth, which could screw things up a little...
NorthEasterner
Went to Maplin's (whilst they still exist) and got new cable (4 core) and pack of 100 crimps.
So the white with blue dashes goes to the white wire of the drop down cable? This should then go into socket B?
Then Blue with white dashes goes into Orange wire of drop down cable. Then go into socket A?
I'll give that a try.
NorthEasterner
Unfortunately new cable hasn't solved things neither has re-crimping.
Internet works regardless which way you put your two wires in either A or B but phone line doesn't.
Tearing my hair out now Undecided
Mustrum
Fixes: 81
Faulty Master Socket? Or using the wrong connection points. Have you got any other socket you could use to prove it? Even an extension socket should be able to get dial tone, although don't expect the phone to ring.
NorthEasterner
All sorted - swapped the White Blue for the White Orange and seems to have fixed it. Bizarre.
Thanks for your support Smiley
RealAleMadrid
Fixes: 68
That is totally wrong, you now have a split pair, I suggest that your connections to the master socket or the gel crimps were not done properly causing the problems you have been experiencing. Using the wrong wire is not the answer.Roll_eyes
twocvbloke
There's a reason I prefer Krone terminals when working on my phoneline stuff, much more reliable connection than the jelly crimps and far easier to re-make if I made a fluff up in the wiring... Smiley
