Looking for iplayer4.3.1.2.apk
30FTTC06
Fixes: 4
Anybody point me to an older version of iplayer4.3.1.2 ?
Latest version 4.4 has broken for me on Android 4.0.4
Edit: This fixed it 4.3.1.2
3 REPLIES 3
30FTTC06
Fixes: 4
Re: Looking for iplayer4.3.1.2.apk
Issue now resolved with the latest update of bbc media player!
Happy days.
avatastic
SWMBO has an issue with iPlayer on ICS in that it won't play radio shows any more.
Is there an additional app called BBC Media Player that needs to be installed along side it to make it all happy again? Or is that a replacement for the iPlayer app?
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
30FTTC06
Fixes: 4
I've just downloaded the Radio app which appears to work ok on my version of 4.0.4 on a Galaxy tab 10.1, Yes I also have the bbc media player app installed then the iplayer and radio plugins ontop of that.
My problem was with the iplayer just not playing after about 5 seconds, in all honesty I don't use the radio app, I also have the same issue with Iplayer if i try to use iplayer through any web-browser, but that has been broken for a long time now.
iplayer radio  version 1.6.3.1556700
iplayer          version 4.4.1.32
media player version 3.0.1.2
I updated the bbc media player yesterday to the latest then re-installed the lastest version of  bbc iplayer. hope that may help in some way. I had to restart the pad when I installed the radio app, big wobble! but ok after.
Very frustrating I know.....
