Laptop won`t connect via ethernet cable.
shutter
Fixes: 67
Two Laptop.... both running Linux Mint 21.2 Vera  - Mate edition
Asus Laptop. connects to the internet via Ethernet  and also via WIFI.
Router is upstairs, and connection to it, is via Power Plug adapters. (and new ethernet cables ) Works really good..On the Asus..
Toshiba 12inch Satellite Pro will not connect via the (same) ethernet cable  but will connect via WIFI.
I have been through the BIOS settings to make sure that LAN is enabled ( has always been, as far as I know ! ) .
I have disabled WIFI  but kept Networking enabled
Icon shows "broken" connection and Ethernet Network "disconnected"
I have copied the same information from the Asus to the Toshiba on the "Editing Wired Connections" page.
on the Connection Information page.....
Using the same Interface name for the router
The same Hardware address.
On the IPV4 section  Using the same IP address
Same Broadcast Address
Same subnet mask
Same Default Route
Same Primare DNS
I have changed the Main board, on which the LAN socket is, for two others,
( all have same problem) .
Any suggestions to solve the above problem would be appreciated.
Thank You.
43 REPLIES 43
Fixes: 579
Re: Laptop won`t connect via ethernet cable.
@shutter  run '
sudo lspci -v
from a terminal window
Look for the ethernet controller and see if its loaded a driver
shutter
Fixes: 67
@MisterW  Thankyou.
Here is a photo of the Network and Ethernet sections
Fixes: 579
There's conflicting information out there as to whether r8169 is the correct driver for that nic or whether it should be r8101 see https://forums.linuxmint.com/viewtopic.php?t=385186 for example.
I think you need to do some research
shutter
Fixes: 67
OK... @MisterW  Thanks for the linky and your time.  Much appreciated.  Sending you a P.M.
shutter
Fixes: 67
@MisterW
After some several attempts to follow the bits and pieces of the linky`s  ( and your advice in PM`s).. I have had some PARTIAL SUCCESS.
The 8101 driver is now installed... and the socket accepts that a cable is inserted, and the driver seems to be searching for something. as where the connection icon is on the (bottom task area) panel, the two plugs have been replaced by a curly swirly icon, indicating that it is searching, Also there is a pop up message saying requesting ethernet address
After about 1 minute or so, it stops for a second only, and shows the two plugs, then disappears and resumes searching. Also, a message appears at the top of the screen saying "Disconnected".
Is there a way to manually enter an ethernet address for "Wired Connection 1".
Fixes: 579
Yes, select Edit connections from the network menu and change the wired connection from DHCP  to static ip
But I would be concerned that there's still an underlying problem as it isn't getting an address via dhcp?
shutter
Fixes: 67
OK   thanks... I`ll  give that a try. and report back
Just a thought, but have you tried running Mint in Live mode, (I think it is called?), where you boot from an installation DVD or USB drive, but don't click the "Install" icon on the "Live" desktop?
That might give a view on if your existing install has become corrupted.
I did that a few years ago when I had similarly baffling issues - Cinnamon is my desktop of choice though! 😀
shutter
Fixes: 67
@Anonymous  Thanks for  your input... I have been using Mint for a long time... and never had this problem UNTIL I got this Toshiba Satellite Pro 12 inch, to replace a 10 inch laptop. ( which had no problems running mint or wired connection! )
I don`t think the install of mint is corrupted, as it was run from the same Live USB as for the main ASUS laptop.  Both installs were from a new download and done within 24 hours of each other.
MisterW has pointed at the driver, and from the linky he provided, it seems it`s been a bit of a problem with others.
@MisterW  I have done a MANUAL insert of the IP address
I put 255.255.255.0 in the Net Mask Column,....but it has changed to 24 for some reason! don`t know if I am doing the right thing.
Wondering about three things now.
1. The driver on the Toshiba ( with the problem) is showing as the "new" driver r8101  but the driver on the ASUS is showing  < iwlwifi >
2. in the above pic there is a small box at the bottom which says "Require IPV4 addressing for this connection to complete"
would this be the "something else" that you mentioned?   regarding not being found by DHCP.
3.  with the Manual insert the message showing on the icon as connected, is as follows
But I get a message Server Not Found...when I try to search with Google.
Also.. despite the message saying it is Active.           ... If I click on the "bold type"   Wired Connection 1  in the listings  I get a quick flash of the "connected"  and then the "disconnected" mesages at top right corner of the screen...
so it appears that, although the "line" is "active".. there is still the problem of actually connecting to the internet via the router.
Fixes: 579
Looks like neither the r8101 or the r8169 driver really like that nic.
I suspect you're stuck with just wireless on that laptop
Nb the iwlwifi you refer on the asus is for the wireless card not the wired one
Fixes: 146
@shutter
You can not use the same IP Address as the wifi network it must be unique, try something else like 192.168.1.50 which is below the DHCP assignment range.
24 bit mask is 255.255.255.0
Dan
Fixes: 579
@Dan_the_Van  good point. I had assumed that @shutter knew what he was doing with assigning static addresses
Also, shouldn't the "Gateway" be 192.168.1.254 - ie the router's IP address? (It says 192.168.1.1 in that picture)
shutter
Fixes: 67
@MisterW Hmm !... no... not really.  just trying to follow instructions.... and hope I don`t make mistakes along the way !.
@Dan_the_Van  Have deleted the previous address... and inserted 192.198.1.50   which remains RED also the 192.168.1.1 ( router) remains RED.. is this correct... or is it telling you (me) something else... as I can`t "Save" the entry (greyed out)
@Anonymous  Changed to .254  and still RED and still no "save"
Correction to above.... error on the 192.168.1.1 insert  (Missed out a dot ! ) now it is correct and showing GREEN
Also error in the first one... ( was two dot ! )  must get these glasses fixed
Connection/Disconnection problem as detailed in previous remains the same.
