Vertical Line - or - "The PIPE symbol"
shutter
Fixes: 67
Can`t produce the "vertical line" or "Pipe" symbol on my keyboard
Keyboard is U.S. Style... layout as per this pic
The keyboard settings are for ENGLISH UK keyboard.. and the type is set as "ASUS Laptop"
According to all the search results I have so far seen... it should be easy to print the verticl bar by using the holding the "shift" key down,  ( backslash - which also does not apper ) .and then the key as shownon the pic... but  it does not work.
SHIFT + Backslash key gives      ~
No "Shift" key  gives    #   (which should be the backslash sign )
Holding the shift key down for all other keys produces this
 ( shift key down ) ¬!"£$%^&*()_+{}~:@<>?
  ( No Shift key  )   `1234567890-=[]#'; /
The other way ( ALT + 1234 on number pad ) also does not produce the "pipe" symbol.
So, where has it gone  ?
15 REPLIES 15
Browni
Aspiring Hero
Fixes: 61
Re: Vertical Line - or - "The PIPE symbol"
Have you tried ALT + 124 ?
shutter
Fixes: 67
@Browni   Left ALT+124 produces     nothing
               Right ALT+124 produces 124
sorry about the typo  1234 should be 124 ! ! ! .
Browni
Aspiring Hero
Fixes: 61
I did think it may have been a typo but am surprised it doesn't work.
Fixes: 145
Hi @shutter
Here are a few for you, just copy paste them | | | | |
or
change your keyboard to US.
Dan.
shutter
Fixes: 67
@Dan_the_Van Gee Whizzz.... Thanks ! .
I did try to change to a US keyboard, but still the same...( or should I have done a reboot after the change  ? )
Edit... just tried again...and it works   ||||||||||||||   so thanks for that...
Fixes: 145
@shutter
I'm not sure a reboot is required, it would drive me insane to have the wrong keyboard, why not buy a USB UK keyboard from your favourite online site?
Dan.
shutter
Fixes: 67
@Dan_the_Van   Have given you a " this fixed it"   but now I have to revert back to the english keyboard .... ( so that I get the " on the 2 and the pound sign on the 3  ) (where did that go  ? ? ? )  ha ha ha. !
A bit awkward sometimes...but at least I know where I can get a short pipe if i need one ! ..
Cheers
Cheesy
RobPN
Fixes: 14
Suggestion if the missing keys or symbols are important, research "Remapping keyboard keys" which might help. Mr. Google is probably an expert on such things.
@shutter
IIRC from another thread, you use Linux Mint on at least some of your devices - is this one of them?
I use Mint, (Cinnamon), with a UK keyboard.
To get the "pipe" symbol I use the right ALT key, (marked ALT GR on my keyboard) and the pipe key which is one in and one up from the bottom left hand corner of the keyboard.
Have you tried the right ALT key and the "pipe" key on your keyboard?
shutter
Fixes: 67
@Anonymous Yes.. using Linux Mint 21 MATE on both my laptops..  As mentioned in previous posts.
checked keyboard layouts. and only way to get the pipe symbol is to change to a US keyboard type
There is a problem with that picture compared to my keyboard though..
Top left key next to the figure 1 shows the pipe symbol
on the bottom row to the left of the (left)ALT I have a "windows" icon key  and to the right of the (right) ALT  key I have something that looks like a "document" icon key.
Also the key above the return/enter key on my keyboard has the pipe symbol and a backslash
If I change the keyboard to US and English US the pipe symbol is in the right place on the keyboard.
Not often used.. but a bit of a pain if I want it .
@shutter
What I have done is make a text document that contains the obscure symbols that I sometimes need - the Euro currency symbol is one.
I keep that document on my desktop, then just "copy and paste" symbols when needed.
Stegs_W
When trying ALT+124 you have to use the numeric keypad on the right of the keyboard, not the numbers on the top row.
shutter
Fixes: 67
@Stegs_W    Yes, indeed,   I knew that. !  Wink
TheRoadCrew
Fixes: 13
On GNOME I have this to find all sorts of symbols:
You might have something similar on MATE.
I can either copy & paste or use Unicode directly.
To use Unicode in a terminal press Ctrl & Shift & u simultaneously and release. Type 007C and you have a pipe (|).
