Internet connection
- Re: Internet connection
Internet connection
27-01-2024 10:46 AM
Many thanks
Ray Nicholson
27-01-2024 6:53 PM
Welcome to the forums @RaymondN
Could you try connecting the laptop via an Ethernet cable and see if you see the same errors/messages?
If that works check for any (I'm assuming) Windows updates and also see if you chosen antivirus is up to date, then after these checks simply unplug the Ethernet - no need to turn the laptop off during the removal
Also within the properties of the wifi adapter - google if you're not sure - make sure it's set to auto.
28-01-2024 9:39 AM
Have you check the network settings? To make sure the network is set to connect automatically....
This is in windows10 -- assume it's the same/very similar in win11
