Hub Two - Port Forwarding
Aikman
Just upgraded to hub two, trying to port forward for a circleloop voip phone system, create port forward and press save but it never saves, tried TCP & UDP &TCP/UDP and still not saving.
Also noticed trying to set static ip and this doesn't save either.
I'm connected through ethernet to the hub & wifi still no joy.
Tags (2)
3 REPLIES 3
bobpullen
Fixes: 327
Re: Hub Two - Port Forwarding
From memory, after entering a port forward rule, there's a '+' icon or similar to the right of the entry field that you need to click before saving. Could it be that you're just missing this step?
Aikman
Tried it, not saving.
It looks to me anytime I try save any changes to any settings in the hub it just doesn't save them.
@Aikman
Have you tried rebooting the Hub2, and trying to set the Port Forwarding again?
Reboots can solve all sorts of problems that have no obvious cause!
