ISP PlusNet Launch Faster Hub Zero 2704n Broadband Router
- ISP PlusNet Launch Faster Hub Zero 2704n Broadband...
Re: ISP PlusNet Launch Faster Hub Zero 2704n Broadband Router
26-01-2015 5:15 PM
Quote from: jelv
Quote from: 11110_110 Why do you need the second router to be on the same range? This would only serve to make it easyer to get into and configure the secound router.
If (as I believe is the case here) you are using the second router as an switch and extra wireless access point its a PITA. Would it even route internet traffic that is not on it's own subnet? Would different LAN devices on two different subnets be able to talk to each other?
eh!
26-01-2015 6:28 PM
The most interesting pages I found about the 2704N were these ones.
26-01-2015 6:57 PM
26-01-2015 7:04 PM
"The modem administration screen resembles the products of D-Link. Perhaps one custom firmware. On the plus side, I point out the fact that the same be in Portuguese, which helps many users.
Access to this screen is given by the famous 192.168.1.1 and the combination admin / admin. However, a few minutes sufficed to discover that many important functions of this modem are simply absent. In particular, the option to enable the controversial TR-069 does not appear, leaving the user with no options. Access via telnet and SSH does not offer a way to access the shell Busybox.
That's when, digging, I discovered a Call info option in the system, in Management. Basically, what it does is generate a file sysinfo.f24 - that looks a lot like an XML - with all modem status information, certainly for technical support purposes. When reading the file, what was my surprise when I saw this:"
"This is the most dirty of history! The user "admin" is simply not an administrator: this is a common user! The true administrator called super! But what would your password? It was enough to use a site conversion Base64 to discover:
User: super
Password: @ c, essoO1
Update: Thanks to Maílson reader, here are also the login information for users of Live TIM also have this modem:
User: T1m4dm
Password: T1m4dm
By accessing the page with these credentials, got access to my complete modem and could disable the function controversy. Including facilitating access via telnet provided more commands - although I am still researching how to access the shell.
Bottom line: The modem Sagemcom is an excellent product, but operators administrators create "fake" users to the user to remove the power to customize it to the extreme. Knowing these credentials avoids the risky task of updating the firmware."
26-01-2015 9:33 PM
If so can anyone with one of these thing's please post a copy of the config file.
26-01-2015 9:50 PM
The sysinfo.f24 file is generated by a page that has a button "to generate a report about the system status and configuration." Well, it is in the ETISALAT firmware for a different model at least.
26-01-2015 10:24 PM
26-01-2015 10:46 PM
26-01-2015 11:12 PM
Quote from: Oldjim Since we are discussing it
I had a play before going back to the TG582n
I have raised the following internally
Respond to ping is permanently disabled on security grounds - so forget about BQM
Telnet is disabled and I didn't find any way of enabling it - so no monitoring programs will work such as Routerstats
Can't fix a device IP address which for me is one reason I won't be using it except for testing
When switching one supplied for ADSL to fibre it has to be set up manually - TR069 won't work and all settings revert to default - and it is then only a three port router
haha it does indeed sound like this device is on BT's command.
By coincidence BT retail homehub's also block ping.
27-01-2015 2:18 AM
Still, it seems a really rubbish router that Plusnet are supplying.
27-01-2015 6:45 AM
It does the job of getting people online, thats all that most people want / need.
If you want / need a better router then go spend your own money on the device that suits you.
Plusnet could supply an all singing & dancing device as standard, I bet you would all moan if the prices where raised up to pay for them.
27-01-2015 8:22 AM
But i believe they should also give you the option of a better router if you decide you need it , Lets face it PN most probably would get a better deal from a supplier than any of us here .
most would not be afraid to pay for a better performing model , which i have said before they could spread the cost over each months bill .
when i first started with PN many moons ago now i had the Thompson until i moved to fibre i was lucky enough to be given a Netgear router not a thompson, and it performs a lot better than the thompson i had before.
so it shows they can acquire a better router if they want .
PS this new one looks horrendous
27-01-2015 9:12 AM
27-01-2015 9:53 AM
Whilst they are still offering only engineer installs, it makes sense for them to continue providing low-cost routers. No doubt the TG589vn v3 is in a completely different bulk pricing bracket compared to the 2704n router.
29-01-2015 8:22 AM
Quote from: DomS Ok - had a play with the new router. It didn't take long ........
Pro's:
Router has an onboard option to switch between FTTC and ADSL
Menu's are snappier and everything is a lot easier to navigate
Devices on network can be time restricted.
Cons:
Bright pink feet.
No guest or secondary network
No USB
Time restricted devices can only be assigned a time - not a day of week as well.
No way to set IP address of router / subnet / turn off DHCP server etc ......
Replying to the bit in bold ... let me get this straight, if I had this router in place of the Technicolor 582n router I currently have, would I no longer
be able to manually setup static IP addresses to any device that I add to my network? If that is true, that is a massive dealbreaker for me.
The Technicolor 582n might be a basic rubbish router compared with others available elsewhere, but at least it lets me do that.
