IP Address
kyle5368
IP Address
Hey all
I was wondering if there is a way to change my IP from static to dynamic?
Kyle5368
17 REPLIES 17
James
Re: IP Address
Hi Kyle,
I've done this for you now.  You're now on a dynamic IP address.
kyle5368
Re: IP Address
Thank you very much!
Again, the amazing Plusnet Staff come to my rescue  Grin
scootie
Re: IP Address
Santiago
Re: IP Address
I have two on mine!
One says I am using a static IP and the other says I am using a dynamic IP
scootie
Re: IP Address
probally stolen the OP's  Grin
mine only showed its self after i think an upgraded from bbyw1 to bbyw3 and then i think i also claimed interleaving tab on another account change
but i have since lost the interleaving since dave did some profile switching to try an sort my iplayer trouble out
James
Re: IP Address
I did have a look myself, and I don't think you can turn static IP off on the member centre.
I had to disable the "static IP component" through our own system.
Networking4Busi
Re: IP Address
Please could I be changed to a dynamic ip address too?  Smiley
Santiago
Re: IP Address
Hello Mr G welcome to the forums, from one of your networkers  Wink
Mav
Fixes: 515
Re: IP Address
Quote from: Santiago
I have two on mine!
I had a similar issue which was discussed by chris in this thread.
Forum Moderator and Customer
Santiago
Re: IP Address
Thank for pointing me to that thread. Was your problem resolved?
Mav
Fixes: 515
Re: IP Address
The extra icon was removed without detrimental effect Smiley
Santiago
Re: IP Address
Ok I need to raise a ticket, thank you
bobpullen
Fixes: 316
Re: IP Address
I have two on mine!
You should just have the one now Smiley
Quote from: Networking4Business
Assuming I'm looking at the right account, you already have a dynamic IP.
Santiago
Re: IP Address
Thanks Bob
