1TB Hardrive
Mav
Fixes: 515
1TB Hardrive
I want to purchase a larger drive and am thinking of the 1TB Hitachi Deskstar 7K1000.B.
Does anyone have any experience of this drive - reliability, etc.
What about TB drives in general (largest drive I have to date is a mere 400GB)? A lot of data to lose in one go but so much cheaper than getting two 500GB drives.
Forum Moderator and Customer
5 REPLIES 5
HairyMcbiker
All Star
Fixes: 21
Re: 1TB Hardrive
Well I just bought one from ebuyer, getting good reviews so far.
Similarly my only experience of large drives stops with 500Gb units, I had one fail after 4 months (a Seagate) but the replacement is fine as is the other drive (can't remember what it is)
I want this one to replace 3 x 300Gb drives I am using (hopefully less power).
Mav
Fixes: 515
Re: 1TB Hardrive
Currently I have 9 drives totalling just over 2TB. Use of a 1TB drive means I can pass a couple of drives to SWMBO and I get less USB cables hanging from the front Wink
THanks for your imput.
HairyMcbiker
All Star
Fixes: 21
Re: 1TB Hardrive
Sounds like my setup, though all bar one of mine are internal.
2x 500Gb Sata } All (Mounted on the MB connector)
4x 300Gb IDE } Linked in a LVM under Ubuntu (Mounted via a 4 port IDE pci card)
1x 80Gb IDE My / drive on the MB controller
+ 1x 300Gb external (USB used for backup)
The new drive will replace 2 possibly 3 of the 300Gb drives, I have just freed one up to allow me to install it when it arrives (My PSU struggles with all these drives  :'()
Mav
Fixes: 515
Re: 1TB Hardrive
I only have 5 internally.
I need to re-arrange them soon as I have a 160GB for the boot drive but, as I don't use that drive for anything except system and installed programs, only around 20GB is actually used. I have a spare 80GB which I'll swap around. I'll probably re-install XP at the same time.
I used to have an IDE card for the PATA drives but found it increased bootup time and I decided to move all but one to external. When I have the 1TB I'll probably move one PATA nack inside.
HairyMcbiker
All Star
Fixes: 21
Re: 1TB Hardrive
Well from a cold boot, I can be at a desktop in about 2 minutes, about 1.5 min from a warm boot, the new Ubuntu boots faster now about 30 seconds to a desktop, so I don't mind too much the init time taken by the "raid" controller. And since this machine is pretty much on 24/7 it doesn't get rebooted very often.
I call it "nas" and it holds my avi's (1.4Tb) and Music (300Gb), love the LVM setup where you can just add a drive and it extends the available space, no mucking about with drive letters or even sub folders, I have 2 main folders called Video and Music and extend them as needed. I used to use naslite, but it was limited to what a drives capacity was, so moved to Ubuntu and got better network performance and I even use this machine most of the time, the only problems it has is a cr*p on-board video. It has a AGP video slot but even with a card slotted in the on-board didn't want to stop working and Ubuntu wouldn't recognise I had a "decent" card installed, even though it was displaying on it.
But with an athlon x2 processor and 3Gb ram it isn't a bad machine. Cheesy
