Google images broken?
VileReynard
Fixes: 20
Re: Google images broken?
You mean Windows users require their instructions in excruciating detail, with copious pictures? GrinGrin
7up
Fixes: 17
and today all is back to normal....
how odd.
VileReynard
Fixes: 20
I'm not convinced. Large images seem to be reduced to a bit less than your screen size.
It's really quite hard to find really big images on Google.
https://www.eso.org/public/images/0206_1_sun_moon_cc_18k_8bit/ gives a selection of different sizes - up to a genuine 81.4MBytes. Cheesy
7up
Fixes: 17
@shutter wrote:
@7up & @thriva  Using Firefox  latest uptodatest...
I get the normal rows of pics..... so I chose one... and clicked on it.... got this
clicked on the face of the big pic... and got this...
Judy Pronk... what a babe she was back then... now images is working i can have a proper perv lol
billnotben
@billnotben wrote:
Most of those damn CAPTCHAs don't seem to work for me now.
What I often get now is it doesn't "tick" and then after a long pause I either get the usual cars/buses or a message about browser problems.
My browser is "nearly" the latest. Updating fixed the  CAPTCHA problem but introduced a few other minor ones as the latest version is more aimed at those with newer video cards than I have.
In the end there was a simple fix just adding a line to the browsers config file. The slightly older version now works fine with CAPTCHAs. They now work in there usual tedious infuriating way.
RobertHoward
 Looks weird. I haven't the such problem at W10.
VileReynard
Fixes: 20
You are not alone...
Except that I'd never normally use Google images, especially the advertising ones.
