'No service listening on remote port' after Windows 10 upgrade
bucksplit
I recently installed Windows 10. Everything seems to be fine, including mail, but when I try to open any browser I get this message via my HP Assistant: 'The proxy server is refusing connections... No service listening on remote port... The remote device or resource won't accept the connection... Contact your ISP...'
Can anyone help?
6 REPLIES 6
Oldjim
Fixes: 63
Re: 'No service listening on remote port' after Windows 10 upgrade
something has set internet connectivity to use a proxy server which you shouldn't - probably windows or the browser - this may help you to disable it http://www.cnet.com/uk/how-to/windows-10-settings-menu-the-network-internet-tab/
ReedRichards
Seasoned Pro
Fixes: 25
It's mostly computer viruses that set a proxy server, in my experience.
bucksplit
Quote from: Oldjim
Thanks, Oldjim. Will check your link out.
bucksplit
Quote from: ReedRichards
Oh please I hope not!!! Cry
ReedRichards
Seasoned Pro
Fixes: 25
Yes, really.  But the virus may have already been removed by your security software, leaving only the changes it made to your settings.
mwillis
I had the  "No service listening on remote port' after Windows 10 upgrade" message on my HP laptop.  A google search on another pc brought me to this post.  Thank you - the cnet link you provided led me to the Proxy setting, where I was able to turn off the proxy server.  Problem solved for me.  If the problem was caused by a virus, hopefully the virus has gone now, according to McAfee.
