Email attachments
- Re: Email attachments
- « Previous
- 1
- 2
- Next »
21-10-2009 4:45 PM
Open Outlook Express
Click Tools, Options, Security tab.
Uncheck:
"Do not allow attachments to be saved or opened that could potentially be a virus".
Uncheck:
"Block images and other external content in HTML email"
Click Apply
Click OK.
21-10-2009 4:50 PM
21-10-2009 5:41 PM
21-10-2009 6:46 PM
Quote from: west As for thunderbird - I have read the set up guide - more than once. The problem is that the site will not allow me to input anything at all ...
If you mean Plusnet's website, that is not where you set it up. You need to actually run Thunderbird on your PC and set up the details from within Thunderbird. The guide on the website is showing you what you have to do on your own PC. Does that make sense?
However, for the moment I would suggest that moving to Thunderbird may be trying too many different things at once. Let's take it one step at a time. Try what Oldjim said first, and we'll see if we can get your existing mail client working. If we draw a blank there then we will have a go with Thunderbird later.
21-10-2009 6:54 PM
22-10-2009 11:07 AM
West
22-10-2009 11:23 AM
Have you considered uninstalling Thunderbird and setting it up again from scratch?
Note that you may need to take copies of a couple of your folders to save the emails you want to keep.
22-10-2009 1:20 PM
Here is something to try. Right click on the link in the email and click where it says something like Copy link location. Go to your web browser, right click in the address bar at the top and click Paste. Then press Enter. If the page opens OK in the browser then at least we know the link itself works OK.
If that does work, then try following the instructions on this page. It could be there is no default browser set, so Outlook Express doesn't know what to use to open the link. If so, this should fix it.
23-10-2009 4:55 PM
I have been going direct to Thunderbird site, have unistalled but still cannot input anything . Nothing seems to work - perhaps I should do what plusnet support say an get an expert in
West.
23-10-2009 4:59 PM
Don't suppose you could get a couple of screenshots of what actually happens?
We might still be able to help
24-10-2009 12:43 PM
West
24-10-2009 12:49 PM
Which internet browser are you using at the moment?
24-10-2009 1:37 PM
Quote from: west Not sure how to do that but I dont see how this will help. I have explained what happens. The only thing I would mention is that when I click on a link the screen freezes and I have to return to the home page and then start again.
You haven't explained.
You just say it doesn't work.
27-10-2009 11:20 AM
West
27-10-2009 2:29 PM
I strongly suspect that you don't need to go to the Plusnet site specifically - any old site would do (your home page for example).
Can I strongly suggest that you create a temporary email and tell people e.g. me about it.
I will send you some attachments (and you will try to open them).
Finally, you can delete this temporary email address.
- « Previous
- 1
- 2
- Next »
