Win 7 & WHS
zpeterk
Win 7 & WHS
I have managed to install win 7 pro upgrade successfully but when I try to map network drive on the WHS it insists that the server is in a domain called kitchen which was the name of the homegroup in its original setup. I have now removed the home group and am a member of "WORKGROUP"
Does anyone know how to remove the domain that doesn't exist  and change it to in workgroup in the map network drive box?
1 REPLY
zpeterk
Re: Win 7 & WHS
After some messing around it would appear that you have to be set up as a work network not a home network
