DD-WRT on plusnet hub one - questions galore
shabbaranks
Im looking to put the DD-WRT firmware on my PlusNet Hub One and I was wondering if anyone has achieved this and if there any negative aspects of doing this?
I cant seem to find the pins which require soldering to connect to a TTL and if anyone has experience of doing this can they offer up some advice please? I have capable soldering skills and shouldn't have issues TFTP'ing the firmware but some guidance is always appreciated. Thank you
1 REPLY 1
RichardB
Seasoned Champion
Fixes: 39
Re: DD-WRT on plusnet hub one - questions galore
The PN Hub One is reported to be the same device as the BT Home Hub 5 type A.
The wiki to install Openwrt can be found at https://wiki.openwrt.org/toh/bt/homehub_v5a
 I tried this on an old BT Home Hub 5 I had lying around. I failed 😞 lost serial comms with the Home Hub.
Despite being not being a novice with a soldering iron, I found it difficult to attach the fires as the pads on the HH PCB are very small.
There is an existing thread over at:
https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Running-OpenWRT-on-the-Plusnet-Hub-One...
Richard
