Can't access Website on Plusnet Router
RichV
My Laptop, Tower and Iphone time out If I try to access Eurocarparts,com (IP address 194.74.180.83)  via the Plusnet router. All other website connect without problems.
If I take my portable devices elsewhere (friends/family) I have no problems accessing that site.
Narrowing it down a bit, my son in law is with Plusnet but has his own router and I can access Eurocarparts.com there. Strangely, he lent me his unused Plusnet router to try at home, in place of mine, and this also failed to connect to the website.
One last thing, if I try using the Tor browser I actually get connected.
Can anyone throw any light on this, any help greatly appreciated.
52 REPLIES 52
Fixes: 392
Re: Can't access Website on Plusnet Router
Sounds like your IP has been wrongly identified by the company as not being a UK one. This happens because BT/Plusnet are using IP blocks they have acquired from elsewhere, and Eurocarparts (or the IP location services they use), have not correctly updated their databases.
RichV
Thanks' John, I have reported this to the Plusnet Help Team but I felt that it stunned them a bit and I was unlikely to get a reply.
In your opinion is it BT, Eurocarparts or Plusnet that I should be chasing for resolution?
Fixes: 392
The Help Team can get a bit confused by this - depends how long they've been on the job.
In answer to your question - Eurocarparts.
RichV
Just as an aside, I recently moved to Plusnet from Virgin. I did not get the problem when on Virgin, is this relevant?
Fixes: 392
No - your IP on Virgin would be from their pool, which is not, AFAIK, changed/amended as often as the BT/PN one, but it is still the responsibility of Euro (or more specifically, their IP location service) to ensure their records are up to date.
If you want to try acquiring a different IP, you ideally need to leave the router switched off overnight, as the 'pools' are relatively small and 'local'.
RichV
John, I'm sorry but I missed out on one vital thing, a TRACERT doesn't get to Eurocarparts and a Ping times out immediately after the Router.
Fixes: 392
@RichV Strange - can you post the first three octets of your current IP?
RichV
192
Fixes: 392
Sorry - I meant the first the blocks of numbers reported by this site: https://www.whatismyip.com/ . I forget not everyone understands computer terminology.
RichV
Thanks John, 33 years mainly on IBM mainframes but a village idiot on Networking - 146
Fixes: 392
Still not enough, I'm afraid - we need 146.xx.xx
RichV
Sorry, 146.198.250
Fixes: 392
OK - give me 10-15 minutes, busy elsewhere.
Fixes: 392
@RichV
Don't know why you have a problem - I have checked using 5 location databases and they all report BT/PN as the holder, location UK.
If you can, try changing your IP by turning the router off all night. Can't guarantee it will work, due to the PN 'local pool' policy, but it might, If not come back and tell us.
