Can't access Website on Plusnet Router
Fixes: 388
Re: Can't access Website on Plusnet Router
I doubt it, Rich. As I said earlier, the 'pools' of IPs are local and fairly small, so even if PN did a session kill for you, you could still end up on the same range - they cannot control what the automatic system allocates.
RobPN
Fixes: 15
I don't know whether the following is helpful or not ...
I have a PN static IP address, I can access the EuroCarParts site with no problem.
I cleared my browser cache and tried to access the site via a VPN I have to my brother in Sweden, again I could access the site with no problems using two different browsers.
A tracert from my PN IP fails as follows
Tracing route to www.eurocarparts.com [194.74.180.83]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 12 ms 12 ms 12 ms 251.core.plus.net [195.166.130.251]
3 13 ms 13 ms 12 ms 84.93.253.91
4 12 ms 13 ms 13 ms 195.99.125.136
5 13 ms 13 ms 13 ms core4-hu0-17-0-6.faraday.ukcore.bt.net [109.159.252.138]
6 13 ms 13 ms 13 ms acc3-te0-1-0-0.faraday.ukcore.bt.net [213.121.193.87]
7 14 ms 13 ms 13 ms ftip003329986-v1-lb.acc3.faraday.21cn-nte.bt.net [62.172.38.85]
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
RichV
Thanks Rob, I'll take a closer look later (up to my neck in Jet Spraying at the mo). However, I can tell you that I've cleared everything including the Hosts file, tried many browsers and DNS servers. I think John was right that it's down to my Public IP which I cannot control. Like you I can access the site using the TOR browser so, as it's very infrequent that I use Euro Car Parts ,at  least I can get through if necessary.
This saga has gone on for days and is driving me nuts however I very much appreciate everyone's time, knowledge and effort.
RobPN
Fixes: 15
@RichV
A guaranteed way to change the IP address you have ATM is to 'buy' a static IP address from PN for a one off charge of £5.
Whether that's worth it to you, or even if it will solve your problem, may be something to consider.
Fixes: 388
Why should a customer have to pay to resolve a company's error? I certainly wouldn't - on principle, @RobPN
RobPN
Fixes: 15
I don't think I would either @jab1 , especially in this case as the site can be reached using alternative means (TOR etc.).  Wink
PS - I didn't pay for my PN static IP address, it was one of those benefits which came with certain PN accounts years ago.
Fixes: 388
Or even IPs that their LP providers (or themselves) have got correctly identified as being UK.😁
RichV
Thanks Rob but to be fair to Plusnet, it looks like a problem at Eurocarparts. Apparently,  their IP-location data is way out of date
and this is the root cause. I have contacted Euro Car Parts about this.
Fixes: 388
@RichV If you ever get an intelligent response from ECP, could you let us know what they say, please?😉
RichV
Of course, no problem. this is what I sent:
Hi, after a long discussion with Plusnet Technical Support (just finished this morning) they said I need to get in touch with you.
Apparently your IP-location data is way out of date and needs to be corrected. This conclusion was reached after three days of tracing so I hope you can look into it. Many thanks.
RobPN
Fixes: 15
@RichV
A possible workaround, depending on which make of car you require parts for, as an alternative you could try GSFcarparts   (GermanSwedishFrench)  Wink
Fixes: 388
Sounds fair enough to me, @RichV .
RichV
Thanks Rob I checked out you link and they look good. However whilst checking out your site I also tried Euro Car Parts and I
connected.
Nothing changed on my side, couldn't connect since moving over to Plusnet, couldn't connect this morning but can as of now.
Maybe this is temporary, I hope not, however I'll try again in the morning.
corringham
Seasoned Champion
Fixes: 23
@jab1 , why is this thought to be a geo-block? I can't see any evidence for that, unless I've missed something in the thread.
Out of interest I've just tried browsing from IP addresses that geo-locate to the USA and Germany, and have no problem connecting - so if they are geo-blocking they aren't doing it on being UK based.
Fixes: 388
After following this through and thinking about it a little bit, I may have been wrong, but it was strange that two people reported the same problem on the same day, both of whose IPs were in ranges which I thought had been transferred some time ago from BT America.
As the OP on this thread at least has now sorted the problem, it is rather academic, but there WAS a problem with ECP blocking what their database identified as non-UK addresses sometime last year - another thread I followed back then until it was resolved.
I am now left wondering if they have now decided to suspend geo-blocking until they have sorted their databases.
The strange bit to this is that Eurocarparts IP itself resolves back to BT?Huh
