CCTV card
- Re: CCTV card
CCTV card
28-09-2012 10:09 AM
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330780743754&ssPageName=ADME:X:AAQ:GB:1123
no it was not 100 quid when i got it.... but when i use in windows 7 everything installs fine however when i go to use software to view my CCTV it only shows picture the first time i install (and it must be clean install of win) after i cloe and reopen software it gives me black screens on all cams...
installed windows XP and it works like a charm....
tryed everything in windows 7 tryed comparability as xp ect any ideas?
Re: CCTV card
28-09-2012 1:23 PM
Quote NOTE: Support up to Vista/Win 7 32bit only!
Vista/Win 7 64bit are not supported! Sorry.
So are using the 32-bit or the 64-bit version of Windows 7?
Re: CCTV card
28-09-2012 1:48 PM
like i said after re-install... first time i use program it works fine after that it gives me blank pictures... o i have xp its perfect... but i want to use win 7 over xp
Re: CCTV card
28-09-2012 5:08 PM
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCMQFjAA&url=http%3A%2...
Or, have you tried 'compatibility' options?
Re: CCTV card
28-09-2012 6:37 PM
Re: CCTV card
28-09-2012 8:00 PM
Re: CCTV card
28-09-2012 9:21 PM
Re: CCTV card
29-09-2012 12:33 AM
althought i have a screen of the software in win 7 ....
confusing thing is.... the software detects the card.... just wont desplay anything... but if i take card out and drop in XP machine it works fine...
so chances are if i install xp on here it would... as it worked fine just after i reinstalled windows 7... but after first close it will not display a image if i try to re-open
Re: CCTV card
29-09-2012 7:29 AM
Quote from: warbleeder ... it worked fine just after i reinstalled windows 7... but after first close it will not display a image if i try to re-open
Does Windows (mis-)apply a software update for the card which kicks-in after the first re-start?
Have you tried 'run as administrator' instead of just running the control software?
Re: CCTV card
29-09-2012 8:41 AM
Re: CCTV card
29-09-2012 9:03 AM
Could you try something like http://www.nchsoftware.com/capture/index.html?gclid=CK3Y-M-p2rICFYqV3godyWEAFw to see if that can pick up images from the cameras?
Re: CCTV card
29-09-2012 9:16 AM
Quote from: ReedRichards Does Windows (mis-)apply a software update for the card which kicks-in after the first re-start?
not sur about update one way im going to find out is reinstall win 7 later and stop updates
yep i ran as admin ...
Do you have anything else TV card-related, such as MediaPortal, installed on the Windows 7 PC? nope
Does Device Manager show the capture card 'working normally'? yes it working fine and shows mem ect as been used by the item
dick:green Quote fixed.
Re: CCTV card
29-09-2012 9:20 AM
Re: CCTV card
30-09-2012 11:58 AM
