Another critical Java vulnerability puts 1 billion users at risk
Steve
Seasoned Pro
Just as Oracle is ramping up for the September 30 start of JavaOne 2012 in San Francisco, researchers from the Polish firm Security Explorations disclosed yet another critical Java vulnerability that might “spoil the taste of Larry Ellison's morning…Java.”
If you disabled Java when the last zero-day exploit was spotted in the wild, then you might consider doing so again . . . or dumping Java altogether? According to Security Explorations researcher Adam Gowdiak, who sent the email to the Full Disclosure Seclist, this Java exploit affects “one billion users of Oracle Java SE software.”
http://blogs.computerworld.com/malware-and-vulnerabilities/21056/another-critical-java-vulnerability...
If life gives you lemons, make lemonade.
Fixes: 17
Re: Another critical Java vulnerability puts 1 billion users at risk
Not just for Windows.
Fixes: 16
It is suggested in the original post that an "alternative" is to DUMP JAVA altogether....
Question.....
What do you replace it with, as so many things rely on us having Java installed. ?
Fixes: 17
I can't think of much that requires Java.
RPMozley
Fixes: 5
Apart from BT & TBB speed testers.
That's RPM to you!!
Fixes: 16
Quote from: ejs
So.... does that answer my question.... no...
can you do without it? if you think so little requires java...?
or what is your alternative suggestion to java?
Fixes: 17
Yes, I do just fine with the Java plugin disabled.
I haven't bothered to select another bittorrent program, there are plenty to choose from, but I don't really use azureus anymore anyway.
Having an alternative for Java itself doesn't really make any sense. Unless you mean an alternative for developing software, then which programming language you might choose instead would depend on what you were developing. I wouldn't have thought many people developing a new website these days would decide to use Java applets for anything.
What are all the irreplaceable Java programs and Java applet using websites you use then?
Steve
Seasoned Pro
@shutter, Since posting this I have dumped Java and so far I have not needed It so looks like I can do without It so far. Why not try doing without It and If you need It just download It and use It, That way you are always guaranteed the latest version, It keeps your system safe and you can un-install It when not required. I have no alternative to Java to suggest
CX
I run 64-bit Windows and I have installed the 64-bit Java JRE. Since neither Firefox nor Chrome are 64-bit, the Java plugin is not available to them. For the sites which require Java (BT Speedtester, for example), I can launch Internet Explorer 9 64-bit. Since I don't use IE 64-bit under any other circumstances I feel this keeps me relatively safe.
Alternatively, install the 32-bit and then in Chrome enable the "click to run plugins" feature and in Firefox install NoScript. These are also helpful for other plugins with less than stellar track records, e.g. Adobe Flash, QuickTime etc.
Fixes: 16
Thanks for the advice.... I am using a program at the moment which does require Java... but I don`t know what other progs use it, other than what the splash screen says about it when you install/update it ...
I do not know what the "threat" is to me, with Java installed,. and most of the techy stuff about threats is beyond my comprehension.
I suppose it is a bit of "head in the sand",.... but if the guys who make Java, know about "threats" to users, then it is their job to counter that and issue, or automatically, update as and when needed.
To post something about a "threat" and say that it should be removed for your own safety, without a simple guide to reasons why it is a threat, is likely to cause panic amongst users...
Hang on a mo... isn`t that what Linux users say about Windows?  it is insecure, and threats abound almost daily... perhaps I should uninstall that too... (cant get on with Linux so end of story ! ! !)
Fixes: 17
The current, and previous big threat, is with the Java plugin: a website can run any program on your computer, or save a file and run that.
Steve
Seasoned Pro
Quote from: shutter
Where did you read that?
To recap, this Java bug is even worse than the last critical Java vulnerability. It puts one billion users of Oracle’s Java SE, Java 5, 6 and 7, at risk. It could be exploited using these browsers: Chrome, Firefox, Internet Explorer, Opera and Safari. If you visit a maliciously crafted website, attackers could gain total control of your PC. Wow, thanks a lot Oracle.
Fixes: 16
Hi Steve.....
and followed up by......
Does that look familiar?  Cheesy
Steve
Seasoned Pro
Well shutter the truth Is out there, I guess Its up to the Individual what they do with It but security should never be compromised IMHO.
Fixes: 16
Shocked............................................ Roll eyes..................................... Undecided
