Bright Sparks
- Re: Bright Sparks
Bright Sparks
25-08-2014 4:23 PM
its running ok but i keep getting a error which i have never seen before , i google it but with no real help so any ideas from the PN Bright Sparks
I get this error when i open ATI Catylist control center
Error is "ordinal 459 could not be located in the dynamic link library urlmon.dl"
Re: Bright Sparks
25-08-2014 4:31 PM
Stuff like this needs caution though.
Re: Bright Sparks
25-08-2014 5:45 PM
Re: Bright Sparks
25-08-2014 6:12 PM
but will uninstall any IE updates to make sure
PS i didnt find that update in my history
@shutter yes it takes 6 time to get rid of it as it reappears after you click it
Re: Bright Sparks
25-08-2014 6:44 PM
Nah... it is seriously annoying when those kind of messages appear...without a usable/reasoned explantion of how to fix the problem..... THEN it would be [OK]
Re: Bright Sparks
25-08-2014 10:13 PM
Re: Bright Sparks
25-08-2014 10:54 PM
Doing a little light googling produces several references, including Microsoft's own forums, the majority of which connect the problem to removing IE.
Quote from: rongtw i remove IE from my system when i install
In most cases it seems to be cured by reinstalling IE and applying any relevant Windows Updates.
Why remove it, no-one makes you use it?
Re: Bright Sparks
26-08-2014 7:09 AM
but will try and install IE to see if it stops this annoying error
Re: Bright Sparks
26-08-2014 7:54 AM
Re: Bright Sparks
26-08-2014 8:59 AM
That's fine if you are 100% certain it's a standalone item with no interaction/dependencies/sharing. Sadly we know Microsoft's history with IE (blatant examples Outlook Express and Windows Update) and that certainly was NOT the case in the past. I for one don't believe they've done a 100% cleanup job with later versions on later OS's.
Quote from: rongtw a believer that if you dont use something why have it installed
Of course it may be the other software that is at fault, assuming that IE is installed and that the required routines are there.
Good tip from RR on noting the versions; I'd do a whole PC search to see where copies are lurking and what they are.
Re: Bright Sparks
26-08-2014 9:04 AM
system restore did not fix it either , wierd thing i tried to do a repair install from my disc , it said it wasnt compatible ?? to my version of windows .
so looks like a secure Erase and start again
Re: Bright Sparks
26-08-2014 11:24 AM
Quote from: rongtw wierd thing i tried to do a repair install from my disc , it said it wasnt compatible ?? to my version of windows .
You cannot go backwards in service packs so if you installed Windows 7 from disc then updated it to Service Pack 1 you could not then use your disc to repair it.
Re: Bright Sparks
26-08-2014 11:35 AM
Re: Bright Sparks
26-08-2014 12:01 PM
Re: Bright Sparks
26-08-2014 12:24 PM
