Blocking internet access to a phone
Doctor23
Hello, I was wondering if anyone could help me. I am trying to block internet access to a mobile phone (android) in my household, I have logged into our router services and selected to limit the device permanently, however the device is still connected to the Internet. Thanks in advance
15 REPLIES 15
Gel
Champion
Fixes: 29
Re: Blocking internet access to a phone
Do you have a router that permits MAC filtering?
That way you can list devices MAC numbers in router to allow only them to access
internet. I've had option on past routers not current PN Hub One.
Doctor23
Thanks for your reply. I have the Hub One and went through the option of limiting access to the device, but the device still remains online.
Gel
Champion
Fixes: 29
All you could do is go into Hub One 'Advanced Settings', then DEVICES, click on the offending Android device, and you can DELETE DEVICE from network.
However, I'm not sure how long this is effective; others may chip in on that.
Doctor23
Thanks I shall give that a try now
ejs
Aspiring Hero
Fixes: 25
Change the wireless password and don't give it to the Android phone.
Mustrum
Fixes: 81
It could still get access to the internet via the mobile signal, although the data allowance could be reduced.
Safeguard could be used to limit sites available, although that would affect all users.
I guess it all depends on what the OP wants to achieve?.
Doctor23
Didn't work I'm afraid. If I change the wireless password will all current users be prompted to input the new one before connecting?
30FTTC06
Fixes: 4
Yes
Doctor23
Shall give that a go, thanks
30FTTC06
Fixes: 4
Make sure WPS is disabled
ReedRichards
Seasoned Pro
Fixes: 25
The risk of blocking internet access via WiFi is that your phone then defaults to using the mobile network instead and you run-up large data charges for accessing the internet when it would otherwise have been free.  I saw a client a few weeks ago who had got through £30 of phone charges in a day because she had been wrongly advised to block WiFi access.
VileReynard
Fixes: 20
Why?
@VileReynard - Maybe to stop his child(ren) from spending their lives on it when they should be doing other stuff like sleeping or homework.
Gel
Champion
Fixes: 29
Am puzzled that deleting from network in HubOne's device list isn't effective; wonder if it needs a reboot after
doing this.
