Setting up TP-Link Archer VR2800 to work with Plusnet Fibre
greshoff
Hello,
Could someone point me to the instructions for setting up a TP-Link Archer VR2800 router to work with Plusnet fibre?
Many thanks
4 REPLIES 4
Mav
Fixes: 518
Re: Setting up TP-Link Archer VR2800 to work with Plusnet Fiber
Moderator's note(s):
Thread moved from Fibre Broadband to Tech Help.
Forum Moderator and Customer
Fixes: 581
@greshoff on the 'Internet connection setup' screen ( page 14 in the manual ) , select PlusNet_VDSL from the ISP list
Enter your username , [email protected] and your password ( the one you use to access the member centre ) and that should be it.
greshoff
Hi
which cables should I use to connect this router to fibre. I assume that I plug my phone line into the DSL socket and connect my computer via ethernet?
THanks
Fixes: 581
Yes, plug the phone line ( via a filter if you havent got a dual faceplate ) into the DSL socket and then connect your computer either by ethernet or wifi
