A new Mac OSX Malware to be aware of.
- Re: A new Mac OSX Malware to be aware of.
17-07-2013 1:31 AM
A new piece of digitally signed spyware for Mac OS X uses a special Unicode character in its file name to hide its real file extension from users and trick them into installing it.
Opening the Janicab .app file will trigger a standard Mac OS X pop-up dialog warning the user that the file was downloaded from the Internet.
However, because of the RLO character in the file name, the entire warning text will be written right to left making it confusing and hard to read.
If users agree to open the file, the malware will install itself in a hidden folder in the user's home directory and will open a decoy PDF document containing what appears to be a news article in Russian.
Janicab continuously takes screenshots and records audio and uploads the collected data to command and control (C&C) servers that it finds by parsing the description of specific YouTube videos.
It also queries the C&C servers for commands to execute, the F-Secure researchers said in the blog post.
http://www.pcadvisor.co.uk/news/security/3457840/new-digitally-signed-mac-malware-confuses-users-wit...
17-07-2013 10:15 AM
Mac users should be a bit more savy about running strange apps.
17-07-2013 10:19 AM
17-07-2013 10:43 AM
17-07-2013 10:51 AM
You should have seen the problem a friend of my better half had who wanted to transfer pictures from her Mac to a USB stick. Eventually she brought the laptop round and I did it for her (it wasn't at all obvious how to do it for a complete noob on a Mac - Me.)
Windows Explorer for all its problems at least makes it easy to do
17-07-2013 11:07 AM
17-07-2013 11:13 AM
Quote from: Hairy But then again they have spent £1000's on their shiny mac, maybe they just like the colour?
£999 for my latest iMac !
17-07-2013 11:17 AM
So why did I find it very non intuitive
Quote from: dvorak disagree it's very obvious, i found it very intuitive and it does just work out of the box
Answer - I have never ever used a Mac before and all I wanted to do was view the folder and copy the files to a USB stick
Also I never did find out how to copy the jpg pictures across I finished up using the export system which re-encodes them
17-07-2013 11:31 AM
Most of my USB transfers of images, files, folders etc I Drag & Drop.
17-07-2013 11:34 AM
Apologies for taking this thread off topic - please let it drop as I no longer have any access to the Mac and so couldn't even try again.
By the way - also have problems doing anything on my better half's android tablet which is a problem when she gets stuck
17-07-2013 11:48 AM
I used iTunes for an iPhone 3 company phone which sadly just worked.
Malware writers will target anything if there's a profit in it.
17-07-2013 11:48 AM
Quote from: Oldjim The odd thing is that she had already tried doing that by dragging the folder containing the files across but it didn't bring the files with it - it was empty on the USB stick
One last thought, perhaps the USB stick needed formatting to a Mac format, via disc utility.
If it was formatted to Windows PC NTFS, it is not write-able to from iMac, unless an extra bit of software is used, which I use.
NTFS is extended FAT for Windows USB
17-07-2013 2:25 PM
Apple browsers targeted by simple JavaScript ransom scam
The attack noticed by security firm Malwarebytes is a mixture of sleight of hand and social engineering that the firm reports that it will work against several Mac-based browsers (using an OSX interpreter) with JavaScript enabled.
http://www.pcadvisor.co.uk/news/security/3458426/apple-browsers-targeted-by-simple-javascript-ransom...
18-07-2013 8:50 AM
Quote from: PlusComUK NTFS is extended FAT for Windows USB
18-07-2013 1:40 PM
I've never used any Apple fashion accessory, though.
