McAfee Internet security for Mac
- McAfee Internet security for Mac
13-08-2013 6:23 PM
Help appreciated
Jamie
Re: McAfee Internet security for Mac
13-08-2013 7:07 PM
Whether Mac's need to run antivirus is a question that is often debated. Personally, I use Sophos Antivius for Mac which is free and seems to work well for me.
http://www.sophos.com/en-us/products/free-tools/sophos-antivirus-for-mac-home-edition.aspx
13-08-2013 7:50 PM
I don't think McAfee or Norton can protect you from that !
13-08-2013 8:08 PM
13-08-2013 8:10 PM
Plus Norton iAntivirus which was free at the time of download, for the occasional additional full sweep.
http://www.iantivirus.com/product/
13-08-2013 9:53 PM
13-08-2013 10:38 PM
14-08-2013 12:22 AM
Quote from: NorthEasterner Think i'll stick with SOPHOS looks quite good, does it work well for you?
I too have it installed on my MacBook and it seems to run pretty smoothly without too much system resource hogging.
Also have ClamXav to continuously monitor any downloads or emails with its Sentry background app. I also reconfigured the scheduled update virus defs to run on start up and not just on a particular time.
14-08-2013 9:42 AM
14-08-2013 7:50 PM
For outgoing emails you could always add a signature to basically say the same, if that's what the effect you want to portray. Also if you're using PN's email then it's probably already scanned for viruses.
