will i be disappointed?
- Feedback
- Plusnet Feedback
- will i be disappointed?
- « Previous
- Next »
Re: will i be disappointed?
13-03-2013 1:35 PM
Have you tried the BT Wholesale test with the extended tests ? Also make sure you're using a wired connection rather than wireless as this can make a huge difference.
13-03-2013 1:36 PM
It's the modem that doesn't allow it, not the router. If you run the BTw Performance Test ignore the red pre-amble except make sure you are connected by ethernet and nothing else is using the Internet, let the first test complete and then click on Further diagnostics at the bottom, enter you phone number and run the test.
The results shows the BT IP Profile (and x1.033 gives the sync speed) - just do a copy and paste of that result page (no need to capture an image).
Also check your Current Line speed (Login required) that shouldmatch the BT IP profile (or be set at the default higher, until your connection has stabilised.
13-03-2013 1:40 PM
"The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider."
Plusnets portal says the following:
"Estimated line speed: 69Mb (Accurate to within +/- 1Mbit) - Checked on 2013-03-13 12:30:42
Current line speed: 78 Mb"
Is there anyway I can get the sync speeds from the bt or modem ?
13-03-2013 1:45 PM
Edit: Just keep trying the Speedtester It will work eventually!
13-03-2013 4:49 PM
Download speedachieved during the test was - 38.1 Mbps
For your connection, the acceptable range of speedsis 12 Mbps-38.72 Mbps .
Additional Information:
IP Profile for your line is - 38.72 Mbps
Upload speed achieved during the test was - 8.76Mbps
Upstream Rate IP profile on your line is - 10 Mbps
am I correct to assume that I am on a 40/10 profile? and if so, could someone from PN please look into it for me?
13-03-2013 4:58 PM
Others have said it has resynced when they have gone into the router settings and done a disconnect / reconnect.
Best to wait for one of the customer service guys to confirm if you're either on the wrong profile or if this is actually the max you'll get from the line.
What was your estimated line speeds before you signed up by the way ?
13-03-2013 5:01 PM
13-03-2013 5:04 PM
Quote am I correct to assume that I am on a 40/10 profile? and if so, could someone from PN please look into it for me?
Adam
13-03-2013 5:28 PM
13-03-2013 7:08 PM
14-03-2013 1:03 PM
anotherone, picbits, the sweepstake resuilts are in
Download speed achieved during the test was - 73.61 Mbps
IP Profile for your line is - 77.44 Mbps
I'm very pleased with that!
What is the max IP Profile possible? is it 80.00 ?
14-03-2013 1:12 PM
14-03-2013 1:14 PM
Hopefully you're all sorted and enjoy your connection speed as much as I'm enjoying mine (slightly slower than yours at 69.9Mb !)
15-03-2013 9:47 PM
- « Previous
- Next »
