speed issues
- Feedback
- Plusnet Feedback
- Re: speed issues
speed issues
26-11-2009 10:30 PM
firstly i havent been with plusnet very long but it seems the honeymoon period is over,
i was getting the max speed my line could handle
my download speed was between 7500kbs and 6000kbs droping to around 5000kbs at peek
but over the last two weeks that has altered drasticaly to between 120kbs and 80kbs droping to as low as 20kbs at peek
however iv sat up a few nights to try a few downloads after midnight and noticed that i DO get the max but only after midnight i also did some downloads in the morning and im still getting the max but as soon as midday comes its back to the snail speed.
sounds like im making this up lol well iv screenshots to back it up
the first was taken at 20 past midnight on the 25/11
the second was taken at 10 past 10 on the morning of the 26/11
the third was taken at 11am on the morning of the 26/11
the forth was taken at 1206 on the afternoon of the 26/11
the fifth was taken at 10past 10 on the evening of the 26/11
all thes downloads were done on files contained it the same serverlocation
as you can see great speed from midnite untill midday then slow and realy slow during peek.
i am getting the speed so i know plusnet can give me the service im paying for, it would be nice if however the fast stuff was during the day and not when i should be asleep
jim:red Agents name removed from lower picture as per forum rules mod:end
Re: speed issues
26-11-2009 11:50 PM
Depending on your package, traffic from these sites is likely to be heavily rate limited.
Re: speed issues
27-11-2009 12:04 AM
the issue is that my speed on any download has changed to slow during the day yet at night(aftermidnight) its as high as it USED to be during the daytime
this isnt only speed on downloads its also ping on a game server i use that used to be around 25/30 now its up between 250/400.but again if i log on after midnight its ok
rate limited?? if thats so then why are the downloads between midnight and midday so much faster than those between midday and midnight,
this is plain and simply a speed issue .
its also causing log in problems with other online comms programs i use like paltalk and ventrilo which time out because its taking so long to connect.
so i think it has nothing to do with what site im downloading from... but thanks for the input
Re: speed issues
27-11-2009 9:52 AM
Our Unlimited product has traffic management in place at peak times, which means that you will see slower speeds between midday and midnight.
You can see the speeds you can expect normally here.
That said, we've had some network issues recently, which may mean that you see speeds lower than this.
Re: speed issues
28-11-2009 12:25 AM
but iv had max speed on my downloads up untill 2 weeks ago, so whats changed at that time????
thats what no one at plusnet can tell me and why the ticket is still ongoing
Re: speed issues
28-11-2009 3:10 PM
There may have been the odd instance where traffic management was not applied when updates/system changes were being made.
Don't forget to multiply kB/sec x8 to get kbps.
Re: speed issues
28-11-2009 4:04 PM
Re: speed issues
28-11-2009 5:31 PM
how come you are paying £25, unlimited doesnt cost that
Re: speed issues
28-11-2009 5:38 PM
Re: speed issues
29-11-2009 12:52 AM
Quote from: pierre_pierre you are not paying for an 8 Mb connection, you are paying for an "up to 8 Mb", and that depends on how far you are from the exchange, the quality of your line, any rubbish put out in you locality etc.
I understand the point about '8mb'. However, I do not expect 450k when I fancy doing a bit of video streaming during the day! Currently my speed Test has shot up to 3.3Mb, although that is at almost 1am!
I'm going to ask a few neighbours as to what they are currently getting on their BT line ADSL too. That may well prove as to whether the problem is with the exchange.
Re: speed issues
29-11-2009 5:58 PM
if ur line is only able to handle 6.5 meg then thats all ull get or so iv been told by BT
so its worth checking to see what your line can handle
my line can handle 6.5 meg and thats what i was getting up untill 2 weeks ago with great download speeds but thats all changed
and now its like im getting les than 1 meg with realy slow download speeds....
Re: speed issues
30-11-2009 5:04 PM
I've had this problem for about two weeks as well. All was ok up to 13Nov then when I next checked my download speed on the 24Nov it had fallen to 320Kbps and has stayed at that ever since. Just hoping that the current maintenance will bring it back to its normal level. (4300Kbps)
Re: speed issues
30-11-2009 10:35 PM
Re: speed issues
30-11-2009 11:17 PM
As you say 302 meters from an exchange should give you a very good speed. There must be a technical fault somewhere.
Re: speed issues
01-12-2009 2:26 PM
caccy i know its getting realy silly, have u checked ur download speeds after midnite, at the moment mine are what they used to be during the day, have a look and see..
69gillan have u checked ur line speed with the bt speed checker, it will let u know what ur line can handle, pierre_pierre posted a link to it a couple of posts ago.
well im still getting the C.R@.p speed and if plusnet dont get it sorted out within the next few days im outa here...
